Question about Kenmore Elite 45986 Front Load Washer
Hi! Please help! Flashing F H repeatedly...
Thanks to all who are reading this...I use my washer a lot due to having 3 kids with autism and my washer stops after about a minute and just flashes F H repeatedly...Our house payment has recently doubled (since Dec) and we really don't have the money to call a service person, so I am hoping that I will be able to fix this problem without having to call someone out. Thanks in advance for any info you can give me. Thanks so much!
Heide Reichmuth
heide@value.net
  • dboleng Jun 29, 2008
    Same problem, will not dispense fabric softner and then flashes F and H
  • 413 Answers
FH is an indication the the machine is not sensing enough water flow into the machine....
The only thing you can do without taking the machine apart is to disconnect the water hoses to the back of your machine and inspect the filter screens for any type of debris that might be restricting water flow into the machine. Typically, the cold water line is more susceptible to foreign matter than the hot waterline.
Posted on Jun 13, 2008
Washer stops mid cycle, flashing LR
Hi
Thanks for using FixYa. Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards. Please rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Power led flashing with 2 other leds flashing
Hello Harold, welcome to FixYa. Can you provide the make and model of the washer you are looking for help with please ? I should be able to help you move forward from that point. macmarkus :)
Jul 14, 2010 | Washing Machines
Have a 3 yr washer that at the end of the wash it stops!
Thanks for writing to Fixya.com.
This sound like a loose connection in the wiring in the machine. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards.
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from bottom, lots of suds.
Hi
Thanks for using FixYa. This may happen due one or more than one of these issues with your washer--
Probably there is something(coins, socks, dirt, debris, etc) stuck inside the drain filter of your washer. You'll need to check the drain filter. To access the drain filter. To check the drain pump follow these steps:
Unplug the washer to completely disconnect electrical power.Remove the bottom front service panel as shown in the first image below.
Also check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
This issue can also be due to clogged drain pump or drain filter, due to which the hose have developed leak. This will cause suds
Please rate the solution if you find it useful and helpful.
Thanks
Rylee
Sep 22, 2009 | GE Washing Machines
Flashing FL
Hi
If you have error code FL it means flood condition i.e. FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
If its LF which means long fill i.e. when the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Fault on Zanussi FS1455W
why should i tell you how i solved the problem????? you want money off of me to tell me how to solver it, so shove off
Aug 28, 2008 | Zanussi FS1455W Front Load Washer
Filter light flashing on bosch exxcel condenser, repeatedly.
This should help you find a manual.
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?psid=31378668&sid=MMHSx20070515x00001a
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 19, 2008 | Dryers
Kenmore Standard 58715182400 Blinking Light
Don't you hate it when you can find lots of people with the same problem, but no one with an answer?
Well I have the same problem. I cracked open the front and found the service manual. Not sure what it does, but holding in "Hi Temp" plus "Start/Cancel" for either 3 seconds or 0.5 seconds is supposed to do something. 3 seconds seemed to reset it, and now it's washing.
Good luck.
Feb 01, 2008 | Kenmore 43142 Front Load Washer
Clean light blinks
Raise the temperature of your water supply. To reset computer open door,within 3 seconds hit hi-temp scrub then energy saver then repeat this. Close door and latch, push cancell button.
Jun 10, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore Elite 45986 Front Load Washer Logo
53 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
