Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Door will only close when held down
Got the Chamberlain Professional garage door opener model 41BD002-2 & have to hold down button to close it until it goes all the way down. Tried moving sensor with orange light & it still won't change. Any other suggestions?
  • 1 more comment
  • coleminer Jul 14, 2008
    I have the same issue. I am able to temporarily resolve it by slightly adjusting the sensors but the issue inevitably comes back - often the next time I try to close the garage.
  • coleminer May 11, 2010
    In my case yes - if I obstruct the sensor it will trip the light on the drive unit but the door still won't close unless I hold down the button.
  • Anonymous Mar 29, 2014
    my chamberlain garage door opener lowers the door a few inches and then goes back up
No flash
Posted on Aug 05, 2008
    Problem Solver:
  • 12 Answers
If you obstruct the photo eye does the light flash ?
Posted on Jun 15, 2008
My Chamberlain 41A5389-1B 1/2HP door opener will only close via the wall push button when it is held down until door is fully closed. Will not close with remote, when using the remote it will start to...
Have you checked the tracks on both sides? If the door closes when you hold the wall button there may be an obstruction or a bad guide. This could exert enough resistance to make it stop and reverse. Holding the wall button allows it to keep going past the problem.
Apr 28, 2017 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener opens with remote but will not close with remote. will open with wall button but button must be held down until door touches floor to close
Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Nov 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
it works but it is annoying: you will have to hold down the button on wired wall unit. hold it until the door closes. also if you have the keypad outside it also works the same way, type code and hold the enter button
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
sounds like the gear drive is getting worn.
also make sure the track are free of any debris.
Aug 17, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears craftsman garage door opener
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Jul 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
That normally happens when the sensors aren't aligned. Both sensors have led lights on them the yellow/orange one will stay on all the time the green one will go out if it cant see the other sensor. Possibly theres a wire that's broken or the other sensor is really out of alignment. Check every inch of wiring from the sensor to the opener, remove wire nuts if present and check the connections. The wires that are used are small, solid and can break easily. Also see if there's a staple that's too tight, move the wire abit where it's stapled and look for damage.
Jun 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
530 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
