Question about BenQ FP731 17" LCD Monitor
My LCD is completely dark - I can 'just' see the desktop, but can't do anything. If I turn the LCD monitor off and then on, I get maybe 2 seconds of the desktop - not long enough to do anything.
  • 1,179 Answers
This sounds like the CFL tubes are not working properly, this is common.
If under warranty then return it, if not then get a technition to replace tubes.
Or it might be cheaper to buy a new 20" LCD screen.
Please do make sure though that the brightness is set to it's maximum by using the menu buttons on the screen itself. It would be some-thing like menu then right arrow to brightness then select button, right button again to increase the brightness.
Please rate, it's the thumbs up.
Thanks
Posted on Nov 04, 2010
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
I have a Samsung syncmaster 933bw 19 inch LCD monitor. It use to work but for some reason it stopped. When I turn it on, it comes on normal and shows the background of the desktop for about 2 seconds and...
hi, try to open the monitor back cover, then look at some of the capacitors in power supply modules if anything looks normal maybe the problem on it are the socket of the flex,
try to unplug aligned and plug it back.
hope this will help......thanks
Jun 18, 2017 | Computers & Internet
Princeton Digital VL1716 monitor - no image and completely dark
1. Most of the time it's the florecent tube about to go out. Check other posts to replace it.
2. Alot is the adapter after a while will lose voltage check the voltage out of the adapter it should be 12V at 4A or 5A would work fine.
Jul 13, 2009 | Princeton Digital VL1716 17" LCD Monitor
Sony SDM-HS75 tft lcd monitor
Sounds like you need a new backlight. Check lcdparts.net
May 26, 2009 | Sony SDM-HS75 17" LCD Monitor
When i turn on my monitor it shows my desktop then shuts off after 10 seconds...never stays on
elainenemeth, Hi, Tell me more! How old is this LCD monitor? Is it out of warranty? Did the "SHUT-DOWN-IMMEDIATE" problem occur without warning? Did the BenQ display a "perfect" image the day before? Did you actually count----1001, 1002----1010 and then it shut down, after pushing the monitor on button. Did you do the "flashlight" test? With monitor connected to a "known-good", fully booted pc with Win Desktop displayed, TURN ON the monitor! Did it display the desktop for 1-2-10 seconds ? What did you see or not see when you pointed the flashlight at different angles about 1-2" inches from the now dark (black) screen? Get back to me with your results. I will offer the best advice possible to you as a consumer/user of LCD/FPD monitor. I'm louie12fix on fixya or lmistyrel @ aol.com Bye for now.
Apr 17, 2009 | BenQ FP71G 17" LCD Monitor
Monitor L17AMTN flashes WinXP desktop, then blanks.
dmellman, Before you open it up, try this! With fully booted pc and WIN DESKTOP screen up, reconnect the L17AMTN . Have a bright flashlight handy so that when the lcd screen flashes on for 1 second and then goes dark, you will want to check to see if the desktop remains on the screen even though you think it went away. Shine the light 1-2 inches from screen at different angles. Has the desk top completely disappeared or is it still being displayed? Do you know about Cold-Cathode-Fluorescent tubes and their Inverter type power supply? I assume that this unit also has a "lay on floor black box switch-mode-power-supply" that is supposed to supply raw 12v-14v dc to the monitor? This symptom is typical of lcd monitor power supply failure, and or inverter board failure. Not to mention the fact that the CCFT's could be a bit tired from use. YOUTUBE has some videos on taking apart lcd monitors. also do search on web for "bad caps on lcd boards" or "bad caps in lcd monitors". I should think that this Tatung might suffer from swollen cap-itis. get back to me with results of your investigation. Im louie12fix on fixya or lmistyrel@aol.com just nrth of Windy City
Apr 17, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Monitor won't stay on.
hi there your problem .your monuter backlights gone so u need to new backlight
Feb 25, 2009 | HP w1907 LCD Monitor
The LCD does goes dark after power on
you mean few second the monitor goes in black. then its come. if it happen, it is ok
Jan 21, 2009 | Sony VAIO® VGC-LS37E PC Desktop
I HAVE ONE SONY MONITOR MODEL SDM HS75.
IT IS SHOWING LED BLINKING FAST NO DISPLAY IF CAN ANY BODY HELP ME TO SOLVED MY PROBLUME.
ASHOK MY CELL NO.09322133048
email.ashoksharma4@gmail.com
Mar 02, 2008 | Sony SDM-HS75 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
129 people viewed this question
Top BenQ Computers & Internet Experts
Steve Allison
Steve Allison
Tommmix
Level 1 Expert
Marvin
Marvin
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
