Question about AO Smith 1 1/2 HP 115/230V 56C Replacement Motor
I have an Aermotor nonsubmersible pump rpm 3450 1/2 hp model # c48b48c09 for my cistern. I thought I was out of water as I could only hear the pump humming and my washer only filled 1/2 up...but I am not out of water and the breaker is not tripped. Please tell me this is not the sign of needing a complete new pump?....Wow...with 2 small children and one income...I really am praying for some options here.
  • 42 Answers
It sounds to me like there is a hole rusted through the discharge pipe of the pump. If you are able to
look into the cistern with a flash light while the pump is running. You might see water swirling around
the pump. This means the pump is good, but the pipe is bad.
Posted on Nov 05, 2010
I need to know what is the RPM for the Pentair dynamo 1 HP?
With very few exceptions pool pumps run at 3450 rpm.
Dec 18, 2013 | Pool & Spa
Trouble 3 hp motor
What kind of problems are you having with this motor?
Rod
US Parts Center
May 03, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
I have a 1/2 Hp a.osmith **** for a well, it pumps up to pressure, turns off then continuosly pushes the water pressure out of the system within a minute or two then it turns on again? Check valve?
You didn't say which way the water was going. I am assuming back into the cistern and it that is so, yes, the check valve has failed or gotten full of trash. Change or clean it, might even be able to replace the flapper seal.
Oct 04, 2012 | AO Smith A.o. Smith T46056 7 1/2 Hp 3...
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Grundfos pump leaking?
If it is starting and stopping, it most likely does have some type of leak. The check vavlve is normally installed on the suction side of the pump, and sometimes instead of a check vavlve or in addition to, there is a foot valve. A foot valve is just a check valve (usually with a screen) at the end of the line in the bottom of the cistern. If you have much suction lift, and the check valve leaks (or any leak in the suction piping) then the water will drop back into the cistern. This will also cause the discharge side of the pump system to drop in pressure, causing the pump to restart. You mentioned removeing the pressure tank, that tank keeps the pump from short cycling when you have low demand on the system. If the pump is higher than the cistern, and you don't see a check valve between cistern and pump then you most likely have a foot vavle in the cistern. Hopefully it's accessable by removing the pipe.
Aug 01, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
Hayward pump has a steady water leak between pump and motor
Replace the machanical seal in the pump. It seals the shaft opening through the pump and is about a $5 - $10 part.
Aug 17, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Sta Right model P2RASF-182L (RPM 3450) sounds like the bearings are gone...turns on, but is very loud and gets very hot.  The water is not circulating either.
If the noise you are hearing is like a grinding, then the bearings are gone. Sta-Rite does not make the motors for their pumps, either AO Smith, or Centurian, makes them, so they recommend that you replace the motor with a new one. You can try a small motor repair shop in your area.
If it is an AO Smith motor, you may be able to find more information at the following website:
http://www.aosmithmotors.com/html/products/productLiterature.html
Jul 12, 2009 | Sta Rite Pool & Spa
AO Smith 1 1/2 HP 115/230V 56C Replacement Motor Logo
393 people viewed this question
Top AO Smith Plumbing Experts
US Parts Center
US Parts Center
Lawrence Oravetz
Gil Shultz
Are you an AO Smith Plumbing Expert? Answer questions, earn points and help others
