Question about Samsung SGH-t219 Cellular Phone
Changing factory dispay settings
I have a t-mobile t219 and the factory color display settings for the contact list are pink and brown and orange. Is there any way I can change these colors? They are so ugly.
    Scholar:
  • 117 Answers
You can cahnge it a little
go to menu
then settings
then display settings
you can change text style and color
Posted on Jul 06, 2008
I need to know what the various colored wires connect to since I needed to remove the old amp and install an after market stereo.
Check the speakers connection and that should give you at least 8 of the colors. The ones left then are going to be ground and power and display power. You can figure those out with a meter.
Aug 24, 2015 | 1994 Volvo 940
Need color list for factory stereo for 99 cutlass
Constant power orange switch power ground Yellow illumination Gray dimmer Brown antenna trigger antenna pink left front + tan -gray right front + light green - dark green left rear + Brown - Yello right rear + Dark blue - Light blue
Jul 29, 2011 | Car Audio & Video
Need to determine whichcolor wires are for the speakers,the constant,switched.
Your vehicle radio color codes below;
Radio 12v blue + radio harness
Radio Ground (chassis)
Radio Ignition pink + radio harness
Radio Illumination yellow/red + radio harness
Factory Amp Turn-on blue/white or pink + radio harness
Power Antenna N/A
LF Speaker +/- purple - green/yellow +,- radio harness or amp under rear deck
RF Speaker +/- brown - brown/white +,- radio harness or amp under rear deck
LR Speaker +/- orange - black/pink +,- radio harness
Notes: On vehicles with premium audio systems, the LR speaker wires are yellow/green - white/orange.
RR Speaker +/- gray - gray/red +,- radio harness
Notes: On vehicles with premium audio systems, the RR speaker wires are red/black - gray/blue.
Feb 06, 2011 | 2007 Nissan Sentra 2.0 SL Sedan
What wire colors do i connect to my old wires in my 95 dodge neon
For Dodge Neons:
Factory in-dash wire harness has 2 pc harness (black plug and gray plug).
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
Metal braid plastic connector attached to back of radio is the ground wire.
May 20, 2010 | Car Audio & Video
I need to know the wiring color diagram for
Radio 12Vorange Radio Ground black Radio Ignition pink Radio Illumination
blue/black Factory Amp Turn-on orange/black Power Antenna green
Left Front Speaker (+/-) red - blue
Right Front Speaker (+/-) white - brown
Left Rear Speaker (+/-) orange - blue
Right Rear Speaker (+/-) orange - green
Mar 07, 2010 | Mobile Authority Car Audio & Video
A digram for the factory wireing for the radio
This color code works for 87-93 mustang factory radio; it might work on yours as well. I'm not sure if it has the same fuses though.
Radio Connector:
Light Green / Yellow - Hot at all times (Fuse 8)
Yellow / Black - Hot in ACC or Run (Fuse 11)
Light Brown / Red - Goes to instrument panel dimming rheostat (Fuse 4)
Red - Ground
White / Purple - Hot in ACC or Run (Fuse 11)
Speaker Connector:
White / Light Green - (+) Right Instrument Panel & Door Speaker
Dark Green / Orange - (-) Right Instrument Panel & Door Speaker
Brown / Pink - (+) Right Rear Speaker
Pink / Light Brown - (-) Right Rear Speaker
Pink / Light Green - (+) Left Rear Speaker
Tan / Yellow - (-) Left Rear Speaker
Light Brown / White - (+) Left Instrument Panel & Door Speaker
Orange / Light Green - (-) Left Instrument Panel & Door Speaker
Hope this helps.
Aug 15, 2009 | 1991 Ford Econoline
Need color code diagram for sterio
I'm not sure what year you have but this color code works for 87-93 mustangs.
Radio Connector:
Red - Ground
Speaker Connector:
Hope this helps.
Jun 19, 2009 | Ford Escort Cars & Trucks
Need a stereo wiring diagram for my van.
Yep!
Here you go...
1995 Mercury Villager Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Purple
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: N/A
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5′ x 7′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Light Green
Right Front Speaker Wire (-): Dark Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Light Brown/White
Left Rear Speaker Wire (-): Light Brown/Yellow
Right Rear Speaker Wire (+): Light Brown/Green
Right Rear Speaker Wire (-): Brown/Pink
That's what they show for factory
K
May 31, 2009 | 1995 Mercury Villager
I need color codes
Constant 12V+ Black/Yellow
Switched 12V+ Red/White
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Samsung SGH-t219 Cellular Phone Logo
90 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
