Question about HP LaserJet 3015 All-In-One Printer
Poor print quality
My hp 3015 lazerjet prints a "shadow-like" copy of the text elswhere on the page.
  • Anonymous Jul 01, 2008
    My HP LaserJet 3015 is also printing a shadow of text when I copy a document. Vertical lines appear in faxes and print jobs. I would love a solution - the only one I have found thus far is nothing - which means purchase a new printer?!
  • Anonymous Mar 13, 2014
    HP Color LazerJet CP1515n
  • 417 Answers
This sometimes happens when using compatible toner cartridges. Change your cartridge to an original failing this the other thing it could be is the fuser unit worn and ghosting. cheapest option is to change the toner cart first.
Thanks Jason
Posted on Aug 17, 2008
The shadow-like copy of text is definitely coming from a faulty tone cartridge, replace it and you will have your solution,
the verical lines are caused by a dirty optical lens which is located under the keypad, just lift that up and you will see a glass bar that is likely dirty, clean it well and this should solve this problem as well
Posted on Jul 24, 2008
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
How do I print several copies of a page on my HP 3015 printer
when you click on print, you should normally get a print window where you can indicate the page to be printer and the number of copies before you proceed with the print job.
Dec 31, 2010 | HP LaserJet 3015 All-In-One Printer
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
My hp laserjet 3015 printer is printing all my pages in just one page
Check your printer driver. The printer is doing what the driver is telling it to do. Check the "printing preferences" button. Set it up to print "1 page per sheet".
Oct 21, 2010 | HP LaserJet 3015 All-In-One Printer
HP Laserjet 3015 - Printed pages are VERY light
Printed pages are VERY light, and the fuser temperature is low. The toner is not fixed on paper. Still it don`t give any errors. A detailed diagram of the power souce have anyone?
Nov 13, 2009 | HP LaserJet 3015 All-In-One Printer
Hp 3015 prints light with new oem cartridge
Machine may be in econo mode. To enable/disable.
Hope this helps
  1. open the Printer Properties (or Printing Preferences in Windows 2000 and Windows XP).
  2. On the Paper/Quality tab or the Finishing tab deselect EconoMode check box.
Apr 01, 2009 | HP LaserJet 3015 All-In-One Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Color and black gets shadow on print out
Go to the printer Setup button, hit Ok, then look for Print Quality, acess print quality and go to calibrate colors, run this calibration for 3 times.
Then go to services and run a 2 cleaning modes
You can try printing blank pages selecting "cardstock" as paper type to clean the fuser
Mar 16, 2009 | HP Laserjet CM2320nf All-In-One Color...
Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Nov 30, 2007 | HP Color LaserJet 2600n Printer
HP LaserJet 3015 All-In-One Printer Logo
245 people viewed this question
Ben Johnson
