Question about Sony Walkman NWZ-S616F MP3 Player
Some mp3 files don't work on my walkman
Error says that the format is not supported, but they play on a Sansa and in windows mediaplayer/
  • 4 more comments
  • plillies Jun 14, 2008
    I am using my NWZ-S616F for mp3 audio only.
    I don't think a hard reset makes much sense. I now have 104 audio files loaded on my player. Maybe a dozen work. The rest don't. The point is some work, some don't, so it must be a problem with the files.
    I am not clear what the objective of this involved process is. Why would installing JSymphonic help? Is it a replacement for MS MediaPlayer?
    OK. I tried an online converter MP3 to MP3 from 45kbps to 128kpbs. The converted file works, but it is 10 time bigger. I will now try converting to about the same bit rate.
    I still don't understand why the problem is occurring, but I seem to be on the track of a solution.
    But if the files are in a bad format, why do they work on my Sansa and in MS media player?
  • plillies Jun 15, 2008
    OK. I ran a conversion to the same bit rate (45kbps) and VBR format. The result is only slightly larger than the original but it works. There doesn't appear to be a need to create a WAV file as an intermediary step.
    Now I just have to find a converter, preferably a batch converter. I've heard of foobar. Do you think that would work?
  • 549 Answers
HOW TO RUN JSYMPHONIC
Download JSymphonic 0.2b
http://sourceforge.net/projects/symphonic/
http://sourceforge.net/project/showf...roup_id=190494
The file I downloaded is JSymphonic0.2beta.zip
Unzip JSymphonic0.2beta.zip somewhere, so you will have a
new directory JSymphonic0.2beta/
Open a console (eg. Konsole) and change directory to the
above directory.
Inside there is a .jar file JSymphonic_0.2b.jarOk, so we have the java application, now we want to run it.
So make sure you have a version of Java which is compatible
with Sun's 1.6 version.
Check your Java version in a console with:
Code: java -version It should report:
java version "1.6.0"If not, then:
Install sun-java6-jre via Adept
Roughly following the instructions in this page: http://www.thelinuxsociety.org.uk/co...sun-java-jdk-6
Open a console:
Code: sudo update-java-alternatives -s java-6-sun Edit /etc/jvm as root:
Code: sudo nano /etc/jvm and add to the top the command:
Code: /usr/lib/jvm/java-6-sun Now try to run the application:
Code: java -jar JSymphonic_0.2b.jar Let me know if this helped, please.
Posted on Jun 14, 2008
  • Sony Master
  • 13,433 Answers
The files need to be converted to the right format.
  • 8 more comments
  • Ekse Jun 14, 2008
    here are a few converters you can try.
    http://www.audio-grabber.com/mp3converte...
    forexamble conver the file that doesn't play on the player to wav and then back to mp3 with the converter. wav is basicly like a RAW sound file without a compression and mp3 is the same with a compression. so this doesn't effect the quality of the music
  • Ekse Jun 14, 2008
    If this solved your problem please click on accept on my solution.
  • Ekse Jun 14, 2008
    plillies did you actually read what I said
    the few files your trying to listen are in a bad format and need to be converted on the pc side first.
  • Ekse Jun 14, 2008
    oh and you dont have to buy a program there are free alternatives.
  • Ekse Jun 14, 2008
    I knew you would ask that question but clearly there is something difrent in those files and to get rid of that extra odd codeing Id suggest you convert the files into wav(faw) format and then convert them back into mp3(compressed)
    That removes anything extra there and should work on your player.
  • Ekse Jun 15, 2008
    and also could you press on the accept button below my solution since we solved the problem. Thanks and if you have any other questions feel free to ask.
  • Ekse Jun 15, 2008
    it may be becouse this spesific player doesn't support the bitrate or there is something else in the file that it doesn't understand. but the other players are a little more advanced and have no problem with it.
  • Ekse Jun 15, 2008
    Yes foobar seems to be able to do that, sounds good.
    http://www.foobar2000.org/
  • Ekse Jun 15, 2008
  • Ekse Jun 15, 2008
    okey, anything else?
    Guru:
  • 1,894 Answers
Did u try a hard reset?
  • dewan nafees ahmed Jun 14, 2008
    Sony
    Walkman Video NWZ-S616F MP3 Player
    is that ir model number of unit?
    i think you will be familiar with the formats the devices support.
    u said FEW MP3s dont support.
    your device supports only mp3 audio.
    and are u trying to play mp3 video?
    just make the extension sure.
Sony mp3 walkman-nwz-e344-trying to create a playlist. error message is cannot play: file format is not supported. this just began. I have made many play lists before. It seem like the walkman has been...
You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Feb 07, 2013 | Sony Walkman NWZ-E344 Digital Media Player
I can't play my songs in my walkman, the songs appear when i connect to the pc and i can play using the computer, but when i try to play with the walkman, simply nothing happens the player does not...
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player. For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Aug 06, 2011 | Sony Network Walkman NW-A1200 MP3 Player
When trying to play music my SONY WALKMAN digital music player NW-A1200 does not play it says i must connect compliant software and transfer songs
MP3 players can only play music files in mp3 file format. You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
Mar 19, 2011 | Sony Network Walkman NW-A1200 MP3 Player
When i try to upload music to my sansa e260, the rhapsody tells me that there a general error with the song (error 80070570). What's that supost to mean?
Mar 12, 2011 | SanDisk Sansa e260 MP3 Player
I have an AA file that I downloaded from audible.com, it's a book. When I try to sync it to the Sony Walkman from Windows Media Play, I get an error. The error says "Windows Media Player cannot sync...
The "AA" file type is not supported in the NWZ MP3 players. However, you are still able to place audiobooks onto your player if you convert the file to one of the supported file audio formats: MP3. WMA, AAC-LC, and PCM. Remember that there are several iterations of MP3, such as variable bit rate and frequency range and the player does not play some of them.
What I do is that I pull the file into Audacity and convert it there. Another option is that if you can burn the audiobook onto a CD, you can then rip to WMP and then sync it to your player. That is how I get my language audiobooks onto my player. The last option, which I have never tried, is to get it into ITunes, then sync it to your player that way. ITunes will automatically convert the file before syncing it onto the player.
Hope that helps.
Jan 07, 2011 | Sony Walkman NWZ-E344 Digital Media Player
Video playback
This means that you may have used a file format that the device does not support. Try looking on the Sony website on the specs to see what kind of file types it takes. Then try again with the proper formats.
Jul 09, 2010 | Sony Walkman NWZ-E344 Digital Media Player
Downloaded books from the library won't play
I was having the same problem when I used Overdrive Media Console to transfer my audiobook files to my Sansa. I updated the license and retransferred and even tried changing the USB settings on the mp2 player. What finally worked? Using Windows Media Player to sync the files instead. When I hooked up my Sansa I chose "use WMP to sync files" and then I dragged/dropped the audiobook files to the mediaplayer window. The audiobook now plays without any problems since WMP made sure the files have the latest subscription update code.
Jun 01, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk sansa e280 will not down load songs
The Sansa player will only recognize certain file formats. The songs with a Red X are not eligible to be transferred to your player, because their DRM license does not allow transfer to certain (or any) mp3 players.
It is best to use songs that are in mp3 format only. They will give you fewer headaches.
iTunes songs will not work with this player.
-Tha Mp3 Doctor
Feb 06, 2009 | SanDisk Sansa E280 MP3 Player
Cant play mpeg4 movies on my sony walkman
I had to convert mine to the same Quick Time format as ipod. see if this helps. There are different format types of mpeg4's
Jun 09, 2008 | Sony Walkman NWZ-S616F MP3 Player
Format Error
I hade just that prob. "format error" used to display. I did this:
1. dwl sonicStage (free)
2.- in the walkman went to menu/initialize/format
then displayed a confirmation screen, I confirmed
it displayed "formating...... COMPLETE"
3.- THEN plugged into the PC and transfered songs with Sonic
and it worked!
Jan 16, 2008 | Sony NW-E003F MP3 Player
Sony Walkman NWZ-S616F MP3 Player Logo
158 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
