Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Can't retrieve WEP code
Alright. I have a WPN824 v2 router, and i want to connect to WiFi on my Wii, but it says the connection is locked. It shows a little locked symbol when i test connection, and I can't find the WEP code to unlock it. I tried typing in 192.168.1.1 and 192.168.1.5 into the IP address, and it won't accept admin as the username and password as the password, which is what I was told to do. Please HELP!!
Please help me find the pass code for my belki router ta
Posted on Nov 26, 2008
  • 6,487 Answers
If the default username and password is not working, try your commonly use username and password coz there's a possibility that you already change it but if it still not working better reset the router.
To reset it juts press and hold teh reset button of the router using a pen then after that you need to reconfigure it back and you should be able to access the setup page of it using "admin" as the username and password.
Hope it helps..
Posted on Jun 13, 2008
How do i set up a wifi conection from my wii to my modem please
Nintendo's wireless connection will only support WEP security. So before connecting it wirelessly, check your wireless router/wireless access point and make sure that IF it has a wireless security configured on it, it's on WEP. So the wireless security should either be Disabled or at WEP. You can check these options on the router's Web UI. If you have a Linksys router, I could help you with it.
follow these steps:
1. Setup Screen > tap "Nintendo Wi-Fi Settings".
2. Select a "Connection slot".
3. Tap "Search for an Access Point. (This will open a list of wireless networks detected.)
4. Select your network (or any network you want to connect to) and connect to it. It will ask your for the network key or WEP key if you have it setup on the router.
Nov 13, 2011 | Nintendo Wii Console
THE WII IS FINDING MY WIFI ROUTER BUT WHEN I DO A CONNECTION TEST IT GIVES ME THE ERROR CODE 51330
Unable to connect to your wireless network error code. I got these instructions from the nintendo site.
Likely cause: It appears that the password (also known as a WPA or WEP key) entered into the Wii console is not the same as what your wireless router is set to allow.
How to fix: Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
Jun 27, 2011 | Nintendo Wii Console
I cannot get my wii to connect to my wireless internet. Ikeep getting errors codes such as 51330
The error code 51330 means that the WiFi cannot get through to your Wii because of the security system you currently have installed on your router. WEP encrypted WiFi routers cannot connect with your Wii properly. To save you some time, I've found the exact link where Nintendo troubleshooting gives you detailed instructions in fixing this problem and getting your Wii to connect to your WiFi.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp? error_code=51330&system=Wii&locale=en_US
Cheers!
Mar 28, 2011 | Nintendo Wii Console
Have misplaced WEP key number is it possible to e-mail it to us.
Unless your Internet Service Provider set up the WEP key for you, there is no way anyone can email or retrieve your WEP.
If the person who set up the router cannot remember the WEP, you can do a hard reset on the router to allow you to connect and create a new WEP.
follow this link for instructions on how to hard reset your router: http://kb.netgear.com/app/answers/detail/a_id/991/~/wpn824-rangemax%E2%84%A2-wireless-router:-frequently-asked-questions
- After a hard reset, you can set up a new WEP and use it on all the devices that you connect to the internet wirelessly.
Dec 31, 2010 | NetGear RangeMax WPN824 Wireless Router...
I go on cod WAW and press multiplayer then i press nitendo wifi connection when i press that it loads a bit then it says cant connect to the COD WAW servers please try again later i dont know wat to do...
Something is wrong with your wireless router. I think Wii's connection to a router is WEP-Shared,or WEP-Open. Try all of the authentications. Ok,just follow this.
1) Load up Wifi Connections and stuff.
2) Go to your computer and go to this website nintendowifi.com
3) http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp Check out which router you have.
4) If you have any of these, your lucky. Just follow this: http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
5) Also look under your router for the WEP key or whatever...
I hope I helped!
Sincerely, Frankwarrior.
Dec 05, 2010 | Nintendo Call of Duty: World at War for ...
Not connecting to the internet with an error code of 52030
Is your router a WNR2000? if it is it cant be connected. Router models included here:
  • CG814WG
  • WGR614 v.9
  • WGR614
  • WNDR3300
  • WNR834B v.2
  • WPN824 v.3
  • Try one of these models.
Aug 24, 2010 | Nintendo Wii Console
Have a wireless arudter by linksys model #wrt310n v2 can t get my wii on line er c 51330 need help
well what you need to do is go to the wii settings then find internet then use connection 2 use wireless then it ll ask to search for the router then select the router your using then security code down it could be wpa-psk or wep key then input that code and then it should want to upgrade it self then it should jump back to the wii main menu
Jan 11, 2010 | Video Game Consoles & Games
Get Netgear 824 wifi working for all computers
I just got my Netgear 824 and I was able to connect to it with my pc and my wifi enabled phone but not with my ibook. Solution: when entering the WEP password enter a $, dollar sign, before the WEP password. I tried it and it worked like a charm.
Mar 09, 2009 | NetGear RangeMax WPN824 Router
Error Code 51331
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
Sep 10, 2008 | Nintendo Wii Console
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
118 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
