Question about Rollei X 8 Sports Digital Camera
I charge the battery and try to start but does not work i test the battery and it is fine so i dont no what is the problem please help thank you
  • 3,037 Answers
Does it try to turn on or anything when you try to start it? Does the lens move? Please provide as much detail as you can so I can help you. Thank you
Benjamin
Posted on Nov 04, 2010
My Worx WG783E cordless lawnmower starts fine but stalls after 3 seconds, can anyone help me fix the problem? Thanks!
need to load test the batteries --and test amp draw to the motor look under dek and make sure no debris is caught around the blade shaft --can cause over heating of motor
Sep 18, 2016 | Cars & Trucks
I have an 03 Chev malibu. I just put a new battery in it. She won't start without a boost.runs fine afterwards.if I let her sit for a bit I will need a boost again..please help
New battery could be faulty or alternator not working.
If nothing happens when you turn the key,to check battery to determine its state of charge. Many starters won't do a thing unless there is at least 10 volts available from the battery. A low battery does not necessarily mean the battery is the problem, though. The battery may have been run down by prolonged cranking while trying to start the engine. Or, the battery's low state of charge may be the result of a charging system problem. Either way, the battery needs to be recharged and tested.If the battery is low, the next logical step might be to try starting the engine with another battery or a charger. If the engine cranks normally and roars to life, you can assume the problem was a dead battery, or a charging problem that allowed the battery to run down. If the battery accepts a charge and tests okay, checking the output of the charging system should help you identify any problems there.
the link below explains a complete diagnosis,
press the helpful button
Engine Won Crank or Start
Jan 19, 2016 | Cars & Trucks
2005 Cadillac CTS tried to crank my car all it will do is one click i took the battery to go get tested and it was 12.3 amps they said it tested fine. So i put the battery back in and same issue 1 click i...
12.3 amps is a bad battery , 500 amps is good, but you meant volts
sure. (by the way sir your battery is discharged, gets forgot?)
12.3 volts rested is a discharged,state ambient temp and can tell by how much using SOC tables.
try jumper cables, try a fully charged battery, 12.6v is fully charged at room temp, rested. barrow a charged battery for friends car.
State of charge.. at room temp.12.3 is 50% charged,
the shops dont tell you that, just GOOD battery, bad,
its your job to charge, it
then when cars starts, the alternator takes over, 100%
the reason you are not going good ,is because no voltmeter in hand. For SURE.
guessing dont work here, only tests and measurements.
1; can you try turning the cars crankshaft by hand.?
siezed, bingo
2: can you hot wire the soleniod small pin to the outside big pin
like here,
http://www.fixkick.com/nocrank.html#test1
if the battery is weak, this test is useless. on all cars.
if it works then the key line is dead
if not the battery ,or cables or starter is bad.
there are 3 parts to a starter,
i repeat, the battery (charged) the cables and the starter.
engine turns by hand. yes.
those are all facts.
another tack.
voltmeter across battery lugs.
crank 0v bad battery or shorted or siezed motor.
12v, starter dead open circuit.
10v typical with fast cranking.
you can see this in 2 dimensions. here.
time is the horizontal axis.
http://www.fixkick.com/Charging/start-voltage-scope.GIF
if living in Nunavut city, cancel my help.
new tables.
Oct 12, 2013 | 2004 Cadillac CTS
06 trailblazer will turn over but not start
I would assume you know how old the battery is
Charged it
Tested it
Dangerous practice jumping a dead battery
Your vehicle & all those made after 1996 are not
to be jumped
You disconnect the battery to test or charge
Jumping can ruin the electronics & cause all sorts of issues
Dec 21, 2012 | 2006 Chevrolet Trailblazer Ext
Replaced battery. still would not start. Cleaned treminal of all corrision. cranked fine. however 1 day later would not start. jump started . drove a couple of miles but when I turned on lights, engine...
Sounds like a bad alternator. Drained your battery and when you turned on the lights it took all the power left in your battery. When you drain a battery down that far, they are real hard to jump, and coupled with the alternator, the car is not producing enough current to start and stay running.
I would take the alternator off and take it to oyur local auto parts store to be tested. If bad, replace it and charge the battery fully before starting. Then check voltage at battery with motor running. Should be 13.2 -14 Volts DC. If not, you may have a bad battery cable or blown fusible link. (especially that if the alternator tests good).....Mike
Jun 15, 2011 | 1996 Ford Explorer
My 2001 ford focus would not start a couple days ago the person that looked at it said it was the cable that connects to the battery terminal .Now it has dont it again this time it want jump start all the...
You need to fix or replace the cable and then charge the battery with a charger. Jump starting with a dead Battery will sometimes trigger the Security system and it will prevent starting.
Most likely your Battery continued to run down because the charging system could not get the electric back into the Battery. So as you drove, the Battery was getting weaker because of the bad connection of the cable.
Charge the Battery, fix the cable, and then go to Autozone or Oreillys for a free scan or charging system test. They will hook up testing equipment and find out if anything needs replacing. The testing is free.
Mar 18, 2011 | 2001 Ford Focus
Hello.my b2050 has a strange behaviour. i haven't use it for one year. when i'm trying charging the battery, the red led doesn't appear. the phone is functionable beacuse the battery is not totally...
Hi,After trying out the charger and it doesn't have problem, and also you tested the battery and the battery doesn't have problem. Don't you think the phone might be the problem?
You can test for the charging port where the charger is been inserted into the phone when charging a phone.It might be dirt that is making it to malfunction. You can use a brush and a methylated spirit to clean up the edge of the phone where you insert the charger.
After testing and still doesn't work, that means you might end up replacing the charger port.
You can contact a skilled personnel for help with parts.
Hope that helps
Thanks for using fixya....
Jan 09, 2011 | LG B2050 Cellular Phone
My car wont start
Take the battery in for a free load test at any Auto Zone
May 25, 2009 | 1983 Ford Fairmont
Won't charge or turn on
maybe the problem was your battery, i just think that youve overcharged it. try to replace another battery. hope that helps!
CHARCOIS
dont forget to rate my post thanks!
Jul 27, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Battery Charging Gateway MX8711
How to replace the CMOS battery. In some cases this can charge the battery and resolve your issue. This often resolves CMOS battery related issues when a computer has been left off for ...
Good Luck, Please dont for get to Vote, Thank You.
Dec 20, 2007 | Gateway MX8711 Notebook
Rollei X 8 Sports Digital Camera Logo
Top Rollei Cameras Experts
Harrie
james laughton
james laughton
Tony Parsons
Tony Parsons
Are you a Rollei Camera Expert? Answer questions, earn points and help others
