Question about Bosch SHU9950 Dishwasher
The control button labels are worn off. I would love to know what each button does.
    President:
  • 1,140 Answers
The simplest thing would be to read the manual. This is available for download (free) from Fixya. Please click on the link below to open the manual:
http://www.fixya.com/support/p117443-bosch_shu9950_dishwasher/manual-388
You will need to scroll down slightly and there is a link just above the manual for downloading to your PC. You can then print the file and keep it with your dishwasher for future reference. If you are unable to open the file, you may also to download Adobe Reader:
http://get.adobe.com/reader/
Please rate this solution if you find it helpful. Thanks.
Posted on Nov 04, 2010
My Yamaha rxa720 remote won’t power on or off the unit. All other remote buttons work and u can manually power on off the unit but not with remote - why? Can I reset the remote?
Most remote controls use a conductive carbon paint on the underside of the button to make contact with the circuit board. The paint on the power button is probably worn out. You can get carbon or silver/carbon paint to repair it. Search for "keypad repair" to find the right stuff. I've used Chemtronics CW2605 to fix a number of items. The hard part is unsnapping the cover pieces of the remote control without breaking the locking tabs that hold it together. Just to make it interesting, some manufacturers hide a screw in the battery compartment or under the label (feel for a screw hole under the label sticker on the bottom of the remote control; if there is one, carefully cut a hole in the label over the screw hole rather than trying to peel off the label).
Chemtronics CW2605 Circuit Works Rubber Keypad Repair Kit Bdent com
Once you open the kit, it has a limited shelf life. You might as well touch up the channel and volume control buttons while you have the remote control open.
Oct 18, 2017 | Yamaha Audio Players & Recorders
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
I can change channels by entering the actual channel number on the keypad, but the channel up and down buttons don't work
The up/down button is worn out (guys do this, since we love to channel surf). Keep the original
remote that came with the TV (they're invaluable), but buy a cheap universal replacement remote
(I got my last one at Dollar General for $8), program it for your TV, and surf with that - you'll
get power ON/OFF, channel up/down, and volume control from any universal remote.
May 30, 2011 | Televison & Video
1990 volvo 740gl far left corner of dashboard has a yellow light thats on constantly. a diagram of a car with a zigzag road. whats that mean.
Either you have a problem with the TCS (Traction Control System), or the TCS is switched off. Most cars with TCS have a button on the shift or the dash labeled "TCS" or "TCS OFF". Find the button, and press it with the car running in gear. If the light goes out, problem solved.
If you cannot manually disengage TCS (no button), or when you press the TCS button the light flashes, check all your brakes and make sure none are dragging or worn out. Also make sure all your tires are properly inflated and balanced, and none are worn out.
TCS works by controlling your brakes on slippery roads and will dynamically apply the brakes to each wheel in order to prevent a skid, even when your foot is not on the brake pedal. During normal driving, the TCS light is out and will either come on briefly or flash when it is active and preventing your car from going into a skid. When the light is on constantly, the system is disabled- either because it was shut off by the driver pressing the TCS (or TCS OFF) button, or because the system has detected a brake problem and automatically disabled it for safety reasons. Worn or dragging brakes, a tire that is flat or worn, or even a wheel that is badly out of balance will cause the system to disable itself, and a severe wheel alignment problem will also.
Apr 15, 2011 | 1990 Volvo 740
Looking for volume control
Take a look at this:
Labelled No.8 = Volume Up button.
Labelled No.9 = Volume Down button.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Oct 07, 2010 | Nokia 6111 Cellular Phone
Zebra printer 2844: prints one label and spits out several empty labels and stops midpoint of a label. To print again, I must correct the label position, turn off then on. Cannot get dump to...
If you are using a windows system please go into the control panel by clicking the start button and choosing control panel. In the control panel go into the printers, right click on the label printer,choose printer properties and then click the tab labeled printing preferences. Choose the page setup tab and please let me know the size that is specified next to the name.
-Kyle
Sep 16, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Oct 03, 2009 | Hunter 52" Ceiling Fan With Light And...
I need the code to program my JR400 & my Toshiba TV
I found a manual online , complete with pictures of the remote , buttons labeled, and program codes.
http://www.remotecodelist.com/remotes/jenson/JR300c.pdf
May 28, 2009 | Jensen JR400 Remote Control
Bosch SHU9950 Dishwasher Logo
1,672 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
