Question about Refrigerators
GE Profile Ice maker/ Water Dispensor not working
Hello all. I have a GE Profile side-by-side and the ice auger does not turn, and the water does not dispense. The control panel self tests ok. I bought this used and just connected the water line yesterday. The fridge is cold, running for a bit over 24 hours, and it's making ice. Just won't dispence ice and no water, the only reason we bought it!
Thanks
  • PhoenixBill Jun 15, 2008
    Thanks tech17, but no luck. I saw on the door it said hold it for 2 minutes, but I went your 5 anyway. When the ice maker tank fills I can here it, I hear the relay click and hear the water flow for a few seconds. But when I push the water lever I hear nothing. I removed the cover behind the control panel inside the freezer and tested the water micro switch with an ohm meter and it tests ok.
Ice and water dispensor won,t turn on.
Posted on Sep 02, 2011
    President:
  • 1,314 Answers
Ok try this for me and let me know how it works there is a water tank in the fridge and on installation you have to hold down the water for about 5mins to fill it up now the ice disp will be a separate issue hold my rating and let me know if your water flowes first
Posted on Jun 13, 2008
The Side by Side GE Profile refrigerator does not dispense any water or ice. It worked for a short period of time but just stopped working. Also, all the options that are suppose to be lite go off when the...
Could be several problems (I'm a homeowner, not an expert). GE had a problem with the water line in the freezer door: not enuf insulation so the line freezes, hence no water flow. I would look at this first, especially if you press the water dispenser handle and you hear the pump, but no water comes out. Ditto if the ice bin is empty or the ice maker isn't making any more ice. If the icemaker is making ice but not dispensing it, then the auger (thing that agitates the ice cubes in the bin) may be broken or frozen. (if frozen be sure ice cubes in bin are loose and not frozen into one big ice cube).
Aug 13, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Broken ice dispenser
try and remove the ice bin.the watch the auger motor while the door is open and the switch help close while some one is tryind to dispence ice.if the auger turns the check and see if the u shaped braket is stripped you can tell this by grabbing it and turning back and forth it should only move one way.if it does not turn then the auger motor does need to be replace.make sure to check the wiring as well.if the motor turn check th is bin and make sure there is no ice jammed in the teeth of the auger this wolud stopp it from turning.i hope this was some help to you good luck. would like to here how things go for you.
Jan 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE REFRIGERATOR'S ICE DISPENSOR PROBLEM
CAN U TELL ME WHAT YOU DID TO FIX THIS PROBLEM. I AM NOW EXPERIENCING THAT EXACT PROB!
Nov 09, 2009 | GE Refrigerators
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile side By side ice maker water leak
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Dec 22, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
527 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
