Question about Polaroid FLM-323B Television
Blue light on flm3238
I read your post so how do i fix the powe supply i am a serice tech for applance
  • lucked Jul 11, 2008
    there is no 10 volt caps on my board is it the same power supply for thr 323B IF SO WHERE ARE THEY LOCATED ON THE BOARD???
  • 15 Answers
I made an easy tutorial for the cap problem. If you are not comfortable doing the work yourself other people have had Radio Shack do the it (very cheap and without shipping).
I feel that we are all in the same situation, if we had the money to get it fixed professionaly we wouldn't be on the internet searching out a solution.
check out this link.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
if you have any problems please email me I will try my best to help you out for FREE!
Posted on Jul 22, 2008
  • 3 Answers
It seems that the manufacturer of the Polaroid FLM-373b and other models of HDTV either used the wrong parts or there is a design problem. I found someone on the internet who said they replaced two capacitors on the power board and it started working just fine. I took the power board out of mine and sure enough the two caps with the 10v markings were swelled. I replaced them with two 25v caps and it is working just fine. All the other caps on the power board were 16v and above. So, I would assume they were shipped the wrong parts or they just put the wrong caps in to begin with. If you want to send me your power board I will fix it for $50.00 plus shipping.
send inquires to:
mott414@@yahoo.com (remove second @)
Posted on Jul 10, 2008
Dvd bahuan stuck in closed position p.o.w on lighting
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 20, 2014 | Televison & Video
Why is the blue light on front blinking
My answer is based on the model number here-AV-56WP74 or similar--blue light blinking is shutdown to protect the power supply in the set.
A few questions you could answer:
before this happened was screen red (too much) or had colors skewed or a little 3d looking?
The most common issue on this set if that is convergence and it can easily escalate to where it shuts the set down and blue blinks constant.
There is a simple way to confirm or deny that issue--Got someone willing to try that? Set will be unplugged and entire front grill under screen removed to try it(I can tell you how and what to do)
If no skill at all--consult a shop--if want I will answer questions or comments you post on this page--(add a comment button)
SD TECH-
Apr 02, 2012 | JVC AV-56WP74 56" Rear Projection...
Power light just keeps flashing blue it won't turn on
rpwest51, Monitor internal "switch-mode-power-supply could be in what is known as "shutdown immediate" mode having sensed (detected) a fault condition with itself or the inverter lamp high voltage supply. You or qualified technician will need to investigate unit to determine root cause down to component level and decide if unit is viable candidate for cheap DIY ($8 parts cost) fix. Above all else, remember this! Your "cold-cathode-fluorescent-lamp" back-lit LCD monitor is no different than any other brand in it's basic design and operation. If you do your research you will also have a good idea as to how those new style curlie-Q energy efficient screw-in CFL ight bulbs work.Read through my higher numbered fixya profile pages and those of other CCFL lcd monitor techs profiles and follow the links you find there for all options that you may have. Hope this helps. 12fixlouie
Apr 12, 2010 | E-Machines E17T4 LCD Monitor
TV FLASHING RD LIGHT AND IT IS ASKING FOR A SERICE TECH
Yes Sir,
Your TV problem on power supply,some of components are damage.Such as power transistor,or diode or micro fuse.If you are a technician you check it or not you go to a service center they solve your problem by simple coast.
Nov 27, 2009 | Mitsubishi WD-62525 62" Rear Projection...
52" Samsung LCD will not turn on. Blue light is on
Have you ssen the back light lit up? If not, the power supply may have problem. If it has back light, then the suspection are the main board, T-con and inverter. Those boards need checked to find out exact defective board.
Aug 17, 2009 | Samsung LN52A850 52 in. LCD HDTV
Won't reset, turn on or read in computer. Blue light isn't on.
same problem this fixed it right away I was suprised
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 20, 2009 | Creative Labs ZEN V Plus MP3 Player
No power
Did the service tech actually look at the computer? I don't know how anyone could make this diagnosis without doing some testing. It could be the motherboard but it could be something else too. I would first suspect the power supply. They frequently go bad. Test that.
Jan 02, 2009 | Gateway 3200XL PC Desktop
Flashes blue and then the tv shuts down
The tech is correct about the internal short inside the blue CRT. There is a way to remove that short by applying a small amount of current to burn the short but that might damage the CRT even more. At this point the CRT needs to be replace.
I will post the instructions on how to remove that short but you will need to have a good regulated power supply and limit the amount of current to 1 to 2 amps.
Apr 24, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue power light is on, but no picture is displayed
The light does indicat that there is power to the sety but that doesnt mean that the power supplys working . Theres nothing uyou can do unless your a trained tech. The set should still have a parts warranty. Good Luck
Jul 28, 2006 | GE 27GT616 27" TV
Polaroid FLM-323B Television Logo
137 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
