If it's like mine, cold air from the freezer isn't reaching the fridge section, so you probably have one or both of 2 problems: the circulating fan isn't working and/or the air flow channels are blocked by frost/ice. The fan is probably inside a structure at the back of the freezer that should be removable to check it.
If the fan's running, you have a freeze-up. Solution is to turn everything off, remove food & wait for the ice to melt which will take several hours unless you speed things up with, say, a hand-held hair dryer. This worked for me!
If the fan's not running, you can find a replacement at your local appliance parts dealer.
Testimonial: "This answer was correct."
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
