Question about Maytag MGR5751AD Gas Kitchen Range
Maytag gas oven
The oven stopped working after a recent power outage, it doesn't do anything. Although the broiler does work. Any suggestions??
    President:
  • 1,314 Answers
If your clock and broiler work then you need to replace the lower oven ignighter remove the oven racks then the bottom plate of the oven its easy then the flame spreader after that you will see a burner bar at the back of that will be the ignighter and just because it glowes dont mean its good just replace it
Posted on Jun 13, 2008
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
My broiler stopped working recently. The oven itself works, but the broiler flames are not lighting. I'm thinking it might be a pilot problem.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
fjfj
Sep 26, 2010 | Maytag MGR5780BDS Gas Kitchen Range
Maytag gas oven quit working
Sounds like the ignitor is bad. They get weak and stop opening the valve completely so it may cause the gas smell.
Sep 02, 2009 | Maytag MGR5729 Kitchen Range
Maytag MGR575qdq gas oven
Replace thermostat in oven and this should fix ya!
(Please rate answer to help keep this site FREE!)
Thank You!
Dec 17, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I was baking in my Maytag range when there was a loud popping noise and the oven stopped working. The broiler, clock and timer do not work either. The control panel will do nothing. The burners work and...
Well on most electronic controlled ranges with the problem your describing alot of time it is the clock that needs replaced. And yes most ovens have 2 ignitors.
Jul 11, 2008 | Maytag Kitchen Ranges
GE spectra xl44 not work
I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag gemini gas oven
you have to allow the broiler to warm up. give it a few minutes (maybe even ten) eventually the broiler will come on.
Nov 12, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MGR4410ADW
You probably need to replace the the ignitor. Even though it glows red does not mean that it is working propery. If it does not draw at least 3.5 amps the gas valve will not open. This can be check with a amp meter.
Feb 20, 2007 | Maytag MGR5751AD Gas Kitchen Range
Maytag MGR5751AD Gas Kitchen Range Logo
222 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
