Question about Frigidaire ATF6000ES Front Load Washer
I have a fridgidaire washer FWT647GHS1. The tube fills with water. Does not spin or move at all. Does drain. If i move the timer it does not spin or anything. Timer seems not to move either/
  • Frigidaire Master
  • 17,130 Answers
Seems your timer is faulty for sure as it is not lcoking on to the contacts in th set program.
The intital cycle seems to work as the water loads into the drum but then the next section of the motor drive is not intitiated. Please check also the water level control, the pressure swtich that needs to contact so as the timer goes on to the spin cycle with the motor working. So once the water level is reached does it stop? if so the timer is a suspect as the pressure switch cuts off the inlet valves but if not the pressure swtich must be checked.
Other wise the timer controller unit is a prime suspect.
Posted on Nov 05, 2010
Washer filling problem
Check to hose to the water level control. It goes from the outside of the tub up to the control which is located in the same area as the timer. It's usually round with the end of that tube and at least 2 wires connected to it. Disconnect the hose and blow air through it. Reconnect and try again. Still no fill, try filling with that tube disconnected. Watch it the entire time as with the tube off the water should not stop. If it fills all the way with the tube off the water control unit has a problem.
Jan 07, 2014 | Roper Washing Machines
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
WASHER FILLS WITH WATER AND AGITATES FOREVER. I
Based on your discription you do need a new timer.
Jun 11, 2010 | Hardware & Accessories
Water runs but doesn't fill tub and wont spin if put on spin cycl
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 09, 2010 | GE WBSE2090A Top Load Washer
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
I have a Fridgidair and it won't drain the water, it pumps the water in and fills but won't drain after it cycles. Please advice!
More than likely check to see if the drain pump is getting any power from the timer, if it is getting power from the timer than the actual drain pump needs to be replaced.If there is NO POWER coming from the timer, than replace the timer.
Aug 14, 2009 | Frigidaire FWS833A Top Load Washer
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Washer won't advance from cycle to cycle
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never
the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates,
Nov 16, 2008 | Danby DDW1805W Designer Series...
Fridgidaire model fwx223lbs4 will wash, but won't spin fast and the water won't drain
HI thanks for the question it sounds like the pump is either burnt out or jammed with debris thanks the appliance doc
Sep 08, 2008 | Frigidaire CWS3600AS Top Load Washer
My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire ATF6000ES Front Load Washer Logo
102 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
