Sylvania Tv/VCR combo Model 6319ccc
Set is dead. No high voltage.
Hi . The TV that I need help fixing is not a projection TV. It's a 19" or 21" CRT television that has built in VCR. I do not have service schematics so for someone to suggest troubleshooting using schematics doesn't help me. I understood that for $10.00 someone who had repaired the same model would tell me what component they changed out to fix problem. TV is still not fixed. Its a Canadian model so its possible that this SYLVANIA model might not have been sold in other regions of the world. TV also makes slight crackling sound from speaker when you pull the plug from wall outlet.
Posted on Jun 14, 2008
What is the onn universal code for sylvania model 6719DFDF
0392. Check this code. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 10, 2015 | Sylvania Televison & Video
Sylvania model 6319ccc. Set is dead no high voltage.
try checking the power supply unit of your tv set
Jun 13, 2008 | Televison & Video
I think the fuse has blown. model number DVC850C 120V Sylvania DVD/VCR combo
HI,
If it totally dead, the fuse is usually the culprit. Just get replaced.
Jan 24, 2011 | Sylvania 6727DE 27 in. TV/VCR/DVD Combo
I turn the tv on and seconds later it shuts off
You probably have a shorted horizontal out put transistor and your TV is going into high voltage shutdown mode. The horizontal is located by the fly back on a metal heat sink.
Oct 18, 2010 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
I need the remote codes for my sylvania model 6420ff
hi! i have here a couple of codes for your sylvania TV, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483. this is for sylvania HDTV 1046, 1465. this is for the tv/dvd combo 1150, 2092, 1464, 2408, 1465, 2260. this is for the TV/DVD/VCR combo 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147. this is for the TV/VCR combo 1145, 3095. hope this helps!!!! goodluck!!!
May 14, 2010 | GE JASRM24912 Remote Control
Sylvania MTS/SAP tv/vcr/dvd combo turning itself off
could be that either the dvd or the vcr are malfunctioning, usually it is the vcr that creates the problem. If you turn tv on and set vol to low see if you can hear the noise of the motor loading or trying to load,with out a tape inside. It may be a good idea to have a qualified tech repair it, these units are difficult to work on and further problems may come up if you are not familiar with the tv.
Dec 31, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Directv remote (RC64) problem with sylvania 6319ce tv/vcr combo
I installed systems for Directv, and whenever i went into a home that had a combo tv / vcr, i could never get a set to program properly. At the most on some sets the remote would turn the tv set on and off, but others functions were non responsive.
Nov 06, 2009 | Sylvania 6319CE 19 in. TV/VCR Combo
My Toshiba MW27FP1 will not turn on but is making a buzzing noise. Is this a common problem with this model?
Ur high voltage is dead,FBT,the flyback transformer is dead,the block of plastic with a red wire with a cap hook to a CRT(tv tube).
Oct 03, 2009 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
High definition box
if you mean the digital set-top box (freeview) then it connects to the tv via scart just to deliver a signal but the vcr uses ordinary aerial input to record it's programs.. you cannot get a 'HD box' to plug into a tv the tv is either HD ready or it is not
Oct 29, 2008 | Sylvania 6313CC 13 in. TV/VCR Combo
Sylvania 6720FDE combo tv/dvd/video
The codes for a combo set are found in the DVD settings or the VCR settings. Try the rca codes for DVD or Vcr and it should work. Although you may find that not all the functions will work properly ( ie: fast forward, open door, etc ). Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
