Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Side by Side Refrigerator - ice maker & water in door
My fridge is about 4 years old and the ice maker works fine, but no water dispenses from the door when the button to dispense is activated. In trying to solve the problem myself, I changed the water filter, check the water lines for kinks, and tested the water link going to the "blue and white" connector valve. When I press the dispenser button when the two lines are not connected, it immediately dispenses from the unconnected water line, so it would seem my problem is between that connection and the dispenser in the door itself... Suggestions??? I have no idea what is going on behind that freezer door panel... Thanks!
  • tgm 819 Jul 05, 2008
    we have put in new connectors
catriver
  • 878 Answers
SOURCE: Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Posted on Jul 24, 2006
  • 116 Answers
SOURCE: water dispenser not working
First of all if your water dispenser is working then we know that the control panel is getting power. If not open the door and manually press the door switch to see of the switch is working properly. The switch will cut power to the dispenser to prevent operation while the door is open. Second you need to check the wiring at the hinge to see if there is a break in it. if you are still having trouble please respond with a model number.
Posted on Mar 10, 2007
  • 1073 Answers
SOURCE: Water and Ice Dispenser shorts Fridge
call ge there is a replacement program for the 05-06 sxs motherboard issue call 800-386-1215 to see if your machine is one of the machines in this program you will need the serial number of the ref before you call
Posted on Jun 13, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
LG refrigerator won't dispense water any more
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
Mar 21, 2010 | LG LRSC-26922 Side by Side Refrigerator
I have a GE Refriderator about 3 years old. Recently the water dispenser stopped working, and the ice maker stopped as well. The ice maker seems to freeze up as it dispenses water in the tray to make ice....
Are you having any cooling problems whatsoever, anywhere? Is there any area in the unit that you dont put food for cooling reasons? if cooling is fine, check the water pressure as it comes into the refrigerator, you wil have to disconnect the water line at the solenoid valve behind the fridge. If pressure is good, pour 4-8 oz of water into ice maker, does it eject those cubes within 24 hours? then replace your water valve(s) One assembly houses a solenoid for both the ice maker and the water dispenser, both solenoids are bad.
If you have further questions, visit my website and send me a question. www.FixMyFridge.net
Mar 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge temperature has suddenly dropped to 15
Check the door gaskets, condenser fan, refrigerator fan and the freezer fan. That should narrow down the problem.
Dec 03, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerator side won't cool
its iced up and needs to be thawed. you can use a hair dryer and make it fast in say 2 hours. the freezer side is blocked from admitting cool air to the fridge side. your defrost timer may be defective or you had a real humid situation that caused it to ice up.
Dec 08, 2008 | GE GSH25SGRSS Stainless Steel Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
112 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
