Question about HP Color LaserJet 2600n Printer
Printer pooler services not running
Will not print, I have tried everything
Not running the print pooler
Posted on Nov 04, 2008
  • 56 Answers
You will need to go to the Control Panel, click on Administrative Tools and then again on Services. Scroll down to Print Spooler and right click on it - then from the menu select restart (or start if the print spooler is not running to begin with).
Posted on Jun 14, 2008
My Lexmark Z705 Will not Print HELP
Use the Vista driver in Windows 7.
Also, make sure that the Print Spooler service in your computer is running. Try following the steps below:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 11, 2012 | Lexmark PhotoJet Z705 InkJet Printer
Dell Photo Scanner / Printer / FAX All-In-One (AIO) Model 964 getting "Printer cannot communicate with computer" error. Technician failed to solve problem remotely over the phone ever after installing the...
Unfortunately on their website it isn't listed as supported by windows 7. Also when a new operating system comes out there is always a lot of issues in the beginning. I have seen quite a few windows 7 problems of this nature. My first question would be did you run the setup in compatibility mode for windows vista? This would be the first thing to try.
Thank you,
Lee
Jan 30, 2010 | Office Equipment & Supplies
I was having a printing on animal care (book) It had 164 pages so I stopped the printing now it starts printing the book all over. How do I cancel this book? Canon iP1800 series
itz problem/error of print pooler..
often happens due to data resent viz. reprint/overload/document mismatch/page error and so on..
itz very common..don't panic..!!..
snatch out all the paper(s) in the tray (but not which is printing)..set all the document in the print pool to delete..just turn off the printer..restart the system..
hope it'll b fine..
best to seek guidance of ur system admin/vendor....
Nov 11, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Ok I posted for the wrong type of printer. I have an HP 1600 Deskjet printer. It has worked fine until I went to print out my insurance ID cards. The printer icon showed up and says 1 docment pending. So I...
often happens due to overload/document mismatch/page error and so on..
set all the document in pool to delete..just turn off the printer..restart the system..
hope it'll b fine..
Nov 11, 2009 | HP DeskJet 1600cm InkJet Printer
hope it'll b fine..
Nov 11, 2009 | HP DeskJet 1600C InkJet Printer
I have installed hp photosmart and get an error message '' restart print spooler error 1068'' I have tried everything but cannot restart my printer spooler.
go back to your services where you start the print spooler. open the dependency tab. there it will tell you what other services the print spooler needs to have running. check them and if any are disabled change them to auto and restart them. reboot and you should be OK.
Nov 05, 2009 | HP Photosmart 7450 InkJet Printer
Trying to install the HP Deskjet F2210 printer onto my Dell with windows XP everything loads except the printer spool. What do I do?
Restart the Print Spooler:
start-> run-> type services.msc-> scroll down to the print spooler service n hit start.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 11, 2009 | HP PSC 2210 All-In-One InkJet Printer
Will not print any documents
first of i need to know what type of computer you aare using then i can help you but you have to check on the process jobs you have in the printing que then delete some of them that might have hang the printer and thus fail to communicate properly with the computer system that is desktop.
get back to me as soon as this helps so we can get another way out kamu2cyprian@yahoo.com
tell me the type of printer you are using
cheers
Jul 04, 2008 | Computers & Internet
Pooler service is not running
If you encounter printer spooler error:
Just follow the instruction:
1. Go to START Menu.
2. Right click My Computer, then click Manage
3. In the right side just click Services and Applications
4. Double click the Services and find the Print spooler
5. Right click Print spooler, then click Start.
6. Go to Start Menu. Kindly check into the Printers and Faxes. If the Printer Icon display. You can start to print.
Other option just reboot your PC.
If you encounter a problem about PC Hardware or Software.
Just feel free to email me at kenny_kenshi@yahoo.com.
Subject: PC Hardware or Software Problems.
I'm Computer Science Graduate in NDU, Cotabato City, Philippines.
Thanks....
Good Day.
Jun 15, 2008 | Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
208 people viewed this question
Seeker5211
Seeker5211
