Question about Zebra Z4Mplus Label Printer
My Zebra Z4M Plus printer is printing, but some part of the label is missing. The printing is good, and starting from a certain point, nothing is printed. There is a straight line (approximately 2cm from the bottom of the label) that separates the printed and the non-printed. What could cause this problem ? Thanks in advance !
    Champion:
  • Zebra Expert
  • 285 Answers
If is line across all the label, need printhead replacement, but first clian the printhead and the rollar, then check if the length and the with is the correct from the driver, last solution, resect the printer to factory defult.
Posted on Nov 12, 2010
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
Z4m printer will miss labels in jobs. I've saved the job in the spooler and if I resend the jobs the blank labels will print out so I know the job is good. Any suggestions welcome.
Check the label size is set correctly in the application. Try using a driver from Nice Label or Seagull Scientific websites to suit Z4M (Not Z4M Plus). Recalibrate the printer and try again. Remember to setup the driver correctly because the driver will override the printer settings.
Nov 30, 2009 | Zebra Z4M Printer
Using multiple printers on switch box. Z4M Plus and Z6M. Sometimes data is missing or printed incorrectly. Font size changes or certain text is missing. We are using Label Vision Version 4.3. It is like we...
The problem with this type of printer is that when you use true type fonts, they are downloaded as graphics. If you have a field which changes on each label there is an overflow of memory. The solution is to use internal fonts for continuously changing datas
Oct 08, 2009 | Zebra Z4Mplus Label Printer
My Zebra Z4m plus start to print in middle of the label,but suddenly to appear next message. error de papel.and stop the machine and the print on the label is in wrong positions
The label is not calibrated. Press keys FEED, PAUSE and CANCEL, turn the printer and release the keys when making the labels. Also verify that the type of material is NOT CONTINUOUS.
Roberto Martinez
Sep 28, 2009 | Zebra Z4Mplus Label Printer
Zebra Z4M Plus
Is the length of the label correct on the configuration print out?
Else try t check if there isn't a feed or print adjust in the parameters
Jun 25, 2009 | Zebra Z4M+ Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
Zebra Z4M plus printing an extra label
Restore factory defaults. If this doesn't sort it out, get back to me and I should be able to point you towards the right solution.
Mar 31, 2009 | Zebra Z4M Printer
My Zebra z4m plus
in the setup menu there is an option to choose what the machine does on powerup and head close. Yours is probably set to calibrate. Just change that setting to "none". Same thing with the pausing. there is a setting to pause after printing each label. Just change that option.
Nov 02, 2008 | Zebra Z4M Printer
Zebra Z4M Plus
this is a color printer or not
Oct 01, 2007 | Zebra Z6M Plus Thermal Label Printer
Zebra Z4Mplus Label Printer Logo
307 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
