Question about Fuji FinePix S2 Pro Digital Camera
Err message on my S2 Pro
Hi, I have the same problem with the error message on my top LCD screen, I replaced all the batteries (Lithium) and the 123A, bit it has not helped. Is there some kind of reset button I can press. I can not even go into the menu. Nothing works
thanks
  • Keshwar Jul 04, 2008
    Err mesage as well
  • krissuh Sep 26, 2008
    that has helped. The problem was with both the batteries and the Lens. The Lens was old and was having problems with the shutter. I replaced the Lens, not only does it work better, but the picture are great. The batteries were also old, needed replacing.
    thanks again.
  • 24 Answers
Try removing the lens, the memory card, and the lithium batteries. With freshly charged AA batteries, turn the camera on. If it comes on without the "err" message in that case, your problem lies with the memory card, the lens, or the lithium batteries. Turn off the camera and add these things until you encounter the problem again.
For a lens, check to make sure the electronic contacts are clean and that the lens gets fully twisted into place, and that if there is an aperture lock, that the aperture is set to the smallest possible aperture (22 or 16, usually).
For the memory card, reformat it elsewhere if it is causing problems. The Fuji S2 is notorious for being picky about memory cards.
Lithium batteries that are slightly run-down can cause all sorts of issues. Your S2 doesn't need to use lithium batteries, except for the built-in flash. You can add an extra AA battery pack to replace the lithium batteries, and that will improve the camera's reliability.
Posted on Sep 25, 2008
Please, a have a problem with my Fujifilm S2 pro:\r\nIn the viewfinder information and in the LCD panel, ever appear a message error "err" when a take pictures. and in the same moment, the sound of shutter speed, is the same of in the slower speed (in 1/1000s = sound of 1/20s)
Please, help me
Thanks
Rogerio Aguieiras
Brazil
rogerio.aguieiras@hotmail.com
Posted on Oct 06, 2010
How can I fix the Taylor LIthium Scale?
take it to were you got it or instuctions show u
Feb 09, 2010 | Taylor "TAYLOR" 73304072 LITHIUM BATH...
Fuji s1, when I power up I get "Err" message on top LCD screen. Batteries are all freshly new.
"Err" message relates to the batteries.
If constantly lit, It's the AA batteries. When flashing, it's the lithium batteries. It can also be the tiny switch in the media door. Try activating it gently with a pointy object to see if the message disappears.
Dec 05, 2009 | Fuji FinePix S1 Pro Digital Camera
Err When Taking Photos.
Mine is doing the same. With all new batteries try squeezing the AA battery holder inwards to improve contact. This fixed mine temporarily. Long term you'll need to get the contact fixed by a camera tec.
Mar 02, 2009 | Fuji FinePix S2 Pro Digital Camera
Err..message from top displays on my FujiFilm FinePix S1Pro
This problem is caused by the plastic memory card door.
There is a door that hides the memory card on the back of the camera.
The door has a small plastic part on the left side that when the door is closed fits inside the camera.
When the door is open this part is exposed. It is right next to the "^" in "^ PUSH TO EJECT"
If you place one drop of superglue on the top of this little plastic part of the door(when open) and let it dry overnight(LEAVING THE DOOR OPEN OVERNIGHT.)
This will slightly build the plastic up about .05-1mm.
The problem is caused by the plastic part being about 1mm too small, liking resulting from normal wear.
I have tested this, and it seems to have resolved my issue with the S1 Pro I bought on e-bay
John C. Vincent
yellowcaseartist.com
Jan 28, 2009 | Fuji FinePix S1 Pro Digital Camera
Fuji s1 pro problems
ps sorted manual downloaded free from fuji uk
problem still persists after being sent to fuji they informed me repair costs would be £389 and thats it no breakdown of what the problem is just
FAULT
great service NOT.
so they think i would pay £389 for an 8 years old superseded many times s1 pro against the cost of fuji's latest s5 pro being less than £450.
******* jokers
Nov 02, 2008 | Fuji FinePix S1 Pro Digital Camera
Fuji finepix s2 pro
the lithium batteries power the flash and some of the metering. But if they drop below a certain power, the camera dies. The F33 error is probably the accidental movement of the aperture ring on the lense. If you get the error, check the aperture ring is set.
Aug 11, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji Finepix S2 Pro
Ensure the batteries are the correct kind and chemical makeup (yes it does make a difference!)
try using lithium or alkaline as oppose to standard =]
Otherwise there may be an issue with the camera itself, check for warranty? if it isnt under warranty, document the error message/number, consult the manual AND the support site for the manufacturer.
good luck! =]
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
The Camera Fuji FinePix S2 Pro1 is not starting up
Generally, in indicator on the back display shows empty battery; sometimes after a short a message Err on a display
Feb 24, 2008 | Fuji FinePix S2 Pro Digital Camera
Error msg fuji s2
couple of things:
I take it that "Err" shows on the display ? This can be caused by a number of things, including the aperture ring on the lense being in the wrong position. Make sure its set to the orange number. The 'err' message isnt generally shown for a power problem. If you have a DC power lead, attach that and see if you can get the camera to work.
Batteries are a nightmare for the S2.
Firstly, if looking for rechargeable AA's, you need at least 2300mAh. Maplin are doing a good deal till the end of the month on them; http://www.maplin.co.uk/Module.aspx?ModuleNo=46414
If you have the small lithium batteries in, then take them out. If the camera senses that they are in there, it will try and use them -even if they are depleted.You can replace them with CR123a batteries, but unless you want to use the on-camera flash, I wouldnt bother. DONT BUY RECHARGEABLE CR123A s !! They do not have anywhere near enough power.
Summary; Check aperture ring remove/replace CR123a (High quality replacement) Use high power AA's
let us know if this works
Nov 12, 2007 | Fuji FinePix S2 Pro Digital Camera
Error
Before the heart attack, check your lens. I believe its the D series lenses that need to be set to all the way open. I get this "err" alot, and then look down to see that Ive rotated the appature.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
969 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
