Question about Toshiba Computers & Internet
Toshiba M115-3094 start up problems
I keep trying to start my laptop and a menu pops up with 5 options: Safe Mode, Safe Mode with Networking, Safe Mode with Command Prompt, Last known working Configuration and Start up windows regularly. I've tried all 5 of the options and none of them will work, so I can't even get to the desktop. Does anyone know how to fix it? I really need the files on my computer otherwise I would completely uninstall and reinstall windows. If anyone can help it'd be greatly appreciated!!
Thanks!
    President:
  • Toshiba Master
  • 1,314 Answers
Okay it sounds like you need to reinstall windows. However, doing so will erase everything on your hard drive. So we need to get that data off your hard drive. You can do this either by purchasing an internal hard drive to usb cable and hooking it up to another computer or by booting with a bootable linux distro, connecting a flash drive and copying the info over that way. Once you have the data safe, you can try booting from your XP disc and try the repair option; this will remove the windows files and leave your data in tact but you should really back it up first.
Also you may want to run a chkdsk on the drive; that may help solve the problem.
Posted on Jun 14, 2008
Laptop toshiba can't find my wireless router realtek rtl8187b wireless 802.11b/g 54mbps usb 2.0 network adapter
Try checking your computer's driver. Right click on Computer. Go to Device Manager. The device drivers are listed in the device manager. Drivers are used to make your computer parts communicate with the operating system. If it has a problem, then the part won't work.
Check for your wireless driver - update it. If no go, then try turning off your wireless adapter in your computer and turn it on. Check = if no go. Try going to safe mode with networking.
To go to safe mode. Do the following:
1. Restart your computer. While it's starting or booting, keep tapping F8 until you see the options to go to safe mode with networking. Use the arrow keys to highlight safe mode with networking.
2. Let your computer start in safe mode. Check if wireless is working fine.
If you want to avoid this kind of problem in the future or if you want to make sure that your computer is running well, then install Radarsync.
Nov 26, 2012 | Realtek Semiconductor Realtek RTL8187B...
I have a toshiba laptop & half the keys on the keyboard won't work
Try to go first to Safe Mode.
Bring up the "Start" menu. Select the "Shut Down" option and then click "Restart."
Wait for the Toshiba Satellite A105 laptop to begin its restart procedure. Press the "F8" key at regular intervals (every 3-4 seconds) when the Toshiba logo pops up on the screen.
Continue tapping the "F8" button until the advanced Windows options menu appears. Use the down arrow key to scroll through the list of advanced Windows options.
Highlight the option labeled "Safe Mode." Press the "Enter" key and wait for the operating system to load in safe mode.
On Safe Mode try to use the keys that are not working if it's woking it's a software problem and you need to have a System Restore for the laptop.
If it's still not working go to BIOS Settings of the laptop try to reset it to default settings.
Hit the "Power" button to turn on the computer. Press the F2 key on the keyboard. This must be done prior to the operating system loading; if the Windows OS logo has popped up, it is too late. Boot into Windows, restart the computer, and try again.
Pressing F2 on a Toshiba laptop takes you directly into the BIOS, and any settings can now be changed.
If you have successfully entered the BIOS Phoenix press F9 there will be an option that will pop out after pressing F9 the choose yes, after that press F10 there will be an option that says "Save and Quit." This will save any changes you've made, exit out of the BIOS, and restart the computer. Choose yes again, after that process the laptop will boot up now to your Windows Screen.
Try to use again the keys that are not working, if it's still not working definitely that's a hardware problem, you need to contact Toshiba Technical Support here's the phone number
800-247-7777
to assist you further with this problem or you can drop your laptop to a nearest Authorize Service Provider for Toshiba near in your place.
Hope this helps. :-)
Mar 22, 2010 | Toshiba Satellite A100-S8111TD Notebook
When i turn it my eee pc on it pops up to where it says windows and thats as far as it will but it will only load up in safe mode
Try restarting your notebook and hit the "f8" key after you see the first screen come up. Keep hitting the F8 key until you see a menu that says "start in safe mode" start in safe mode with networking......
Start in last known good configuration....Start windows normally.
Try using Start in last known good configuration.
Hopefully, that will solve the problem that is hanging up your windows from starting.
Brian
Mar 01, 2010 | ASUS Eee PC 1000H Laptop
Cant access laptop apart from boot menu f5 f12...keeps saying tring to fix windows but not getting anywhere...i have alot of photos on there i do not want to lose...have toshiba recovery disc but that will...
Hi There, try booting in safe mode to download your photos to a flash drive or cd. When you first turn on laptop, and see the curser upper left side of screen, keep pushing "f8" to enter safe mode boot. Select "safe mode with networking" and continue on to save pics. Good Luck...
Oct 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
Problems starting my lap top
You will need a xp cd you need to boot from the cd and do windows repair when that option comes up. Don't do the repair console go pass that you will see the repair option.
Mar 20, 2009 | Computers & Internet
Hi again,
Appreciate the rating and review on the Live Session.
At your convenience, would further appreciate an update for any development(s). Please do an "Ask Me" here.
Nov 13, 2008 | Toshiba Satellite M115-S1061 Notebook
Computers & Internet Logo
152 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
