Have you installed any new updates or software or drivers?
If so i would boot in safe mode by pressing F8 on boot up an remove the changes you have made.
If that does not solve your problem i would suggesting doing a system restore through booting in safe mode by pressing F8 at boot.
If that still does not work i would suggest a clean install by booting from your operating system cd.
The
detail of that particular date should show "System Checkpoint" and
time on the right hand side box. Select that date. Go to 'Start' and
then Run Next time you login to windows your issues will be resolved. If you feel that my answers have helped you getting
solution to your problems then please give a vote. Thanks.
Now, Click on Next and System Restore will start and windows will take a
reboot.
After reboot login to windows and
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration
utility' window click on 'startup' tab then uncheck all the applications except
your current antivirus and press apply then 'ok' and then 'exit without
restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in
both spaces.
Now restart windows.
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications.
right click on each application and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and
now you can reboot or turn off your windows as usual from start button.
