Question about E-Machines eMachines Desktop PC
Mouse Cursor Frozen
I Did most recent Microsoft update and Security Update and now the mouse cursor is now frozen on my Emachine with an AMD3100+.
  • ryebo Jun 14, 2008
    Thanks for the tip. Unfortunately, I had already tried this and the frozen mouse cursor is still in the middle of the screen and non responsive. Any other suggestions would be helpful.
  • 2,794 Answers
Try putting the computer into safe mode by shutting down the computer. Turn the computer back on. At beginning of the boot process press and hold the f8 button and select safe mode from the menu.
When the safe mode is done booting up, try moving the mouse around. If it works, restart the the computer under normal Windows startup procedures.
Posted on Jun 13, 2008
Cursor is frozen in middle of screen- having to use my nexus to get this answer
try plugging in a mouse for now, you may need to do a driver update on your system
If you tell me what your laptop model is I can direct you to the driver
or run windows update, may fix the issue
Mar 26, 2015 | Computers & Internet
Acer Aspire One Netbook Freezes Constantly Playing Video
ive got a kav60 netbook and the video and audio freezes, makes a nasty buzzing sound. i also have a problem with my mouse, it goes crazy, or sometimes doesnt respond unless i apply pressure to one side of the netbook (slightly bending). tried disconnecting the touchpad, and applying an external usb mouse, but it sometimes freezes the cursor,or the cursor does its own thing. please help
Aug 23, 2012 | Computers & Internet
How do I fix a frozen cursor on dell inspiron?
make sure batteries have power and have secure seating
or it might be the usb for wireless mouse or lead connecting to the usb port or even a faulty mouse
if this does not fix the problem
restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
click start control panel administrative tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver rollback driver or uninstall also
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 arrows then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
hope this helps
Jul 14, 2012 | Dell Computers & Internet
Toshiba laptop frozen pointer mouse
  • If you're having problems with Windows Update, make sure you're connected to the Internet, and then download and run the Windows Update Troubleshooter for your version of Windows.
  • Download troubleshooter for Windows 10
  • Download troubleshooter for Windows 7 and Windows 8
  • After the troubleshooter finishes, try running Windows Update again and install any available updates.
  • Or,
  • https://support.microsoft.com/en-us/help/947821/fix-windows-update-errors-by-using-the-dism-or-system-update-readiness-tool
  • Mar 15, 2017 | Computers & Internet
    Cursor/mouse freezes
    Hi, this Information apply to the same application for the "Mouse" to function properly.
    I. “To “Enable” the "Mouse" or (Pointer Device) using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
    II. “Highlight”; the item you want to (enable) this being the "Mouse" or “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
    III. You may need to “Update Drivers2_bing.gif?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver2_bing.gif”, click (OK), this will ensure that the application take effect.
    Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
    Hope this Fix it.
    Apr 02, 2010 | Computers & Internet
    Emachine laptop mouse has frozen when turning it
    Go to the manufacturer support website for your computer.. find , download and install all current updates.. That should remedy your issue. And dont forget Windows Updates as well..
    Mar 02, 2010 | Toshiba Satellite M35X-S161 Notebook
    Msk1056 optical mouse lights on won't move cursor
    REPLACE THE BATTERY AND UPDATE THE SOFTWARE AND PUSH IN THE RESET BUTTON ON THE BUTTOM OF THE MOUSE SO IT KNOWS WHAT FREQUENCE TO OPERATE AT
    RODGANDYSR
    Mar 05, 2009 | Microsoft Wireless Notebook Optical Mouse...
    Frozen cursor on new emachine laptop
    Before you plan to return make sure you have done some or all of this things first:
    1. Did you reboot after you installed the Enterprise 2007 ?
    2. Did you make sure that if its a USB mouse that it is securely connected to the USB port ?
    3. Were you able to move your mouse without any problem at all before the software installation ?
    4. Have you had this problem before the installation of Enterprise 2007 ?
    5. Have you done all your software and windows updates ?
    6. Will the mouse work when booting into Safe Mode ( pressing F8 during re-boot before Windows Vista loads) If it does then your softwares need to be updated.
    7. Did you check you device manager to see that theres no yellow exclamation anywhere in the Mice and othert pointing devices or under the USB controller section?
    8. Is there a legacy USB port to be activated on your computer BIOS ?
    If the installation caused your mouse to be frozen then try and uninstall the Enterprise 2007 by using your keyboard and tab to the programs uninstall.
    If your mouse still doesn't move after doing all of the above things
    then try another new USB mouse. Sometimes you may have to wait for several seconds (even up to a minute for new usb mouse detection) before the USB mouse cursor will move. If the second new USB mouse still wont work then return it to where you bought it as it could be faulty usb connector
    Dec 28, 2008 | Computers & Internet
    Mouse Cursor Frozen
    If your plugging it into a P2P (which are the green and purple circular ports that your and keyboard go into) for mouse to get power, it would require a restart. I suggest using a USB mouse because it a plug n go.
    Oct 23, 2008 | E-Machines eMachines Desktop PC
    Microsoft Wireless Optical Comfort Desktop and Mouse combo Freezing Prob.'s
    have you tried pressing the connect button on the reciever then on the mouse so it picks it back up again?
    May 01, 2008 | Microsoft Multimedia Optical...
    E-Machines eMachines Desktop PC Logo
    509 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
