Question about Fuji FinePix S2 Pro Digital Camera
Fuji Finepix S2 Pro
Hi I have an S2 pro for a number of years, I haven't used it for awhile. I replaced both set of batteries but am getting an Err messagae on the top LCD screen. I have turned it off, taken the batteries out and put them back in but can not get rid of the Err message on the top. there is nothing displayed on the back panel. I tried pressing the Menu button, but nothing happens. Please help
thanks
  • krissuh Jun 14, 2008
    Hi, I have just placed new lithum 123A batteries. And the AA batteries are Fuji rechargeables that I have been using for over a year.
    All I get is Err with no numbers.
    I have taken the AA batteries out and the Err message is still there. When I take the 123A Lithium batteries out, everything turns off.
    Is there somekind of reset button.
    Prior to placing the above batteries in, I tried normal batteries (the Fuji were flat) obviously nothing worked so I re-charged the Fuji and tried again, still getting error.
    Before the batteries went flat the camera was working.
    Any suggestions. PLEASE
    Problem Solver:
  • 6 Answers
Ensure the batteries are the correct kind and chemical makeup (yes it does make a difference!)
try using lithium or alkaline as oppose to standard =]
Otherwise there may be an issue with the camera itself, check for warranty? if it isnt under warranty, document the error message/number, consult the manual AND the support site for the manufacturer.
good luck! =]
Posted on Jun 14, 2008
I had an error with Fuji s2pro when i turn it one it give me error plz i need help
Posted on Dec 15, 2008
I haven't heard back yet. Alol I needed to do to correct err message was replace AA batteries. Please send my operators manual.
Please CLICK HERE TO DOWNLOAD the operators manual for Fuji FinePix S1 Pro Digital Camera .
You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site.
Oct 11, 2011 | Fuji FinePix S1 Pro Digital Camera
How to reset to factory settings , my fuji finepix s2 pro. the auto-focus function is not working. Camera can only be focused in the man mode. can you help?
Please try to download the manual in this website it can help you on how to reset the setting of your FUJI Fine Fix S2 PRO
http://downloads.fotosource.com/public/camera_manuals/Fuji/DigitalCameras/FinePixS2Pro.pdf
Thanks
May 09, 2011 | Fuji FinePix S2 Pro Digital Camera
My fuji finepix S2 pro camera can not turn on when i put 2 cr batteries into its grip, when i remove 2 cr batteries it's turn on and work but i can't using flash, error no cr batteries found. Please show...
This is an old post but if you haven't found your solution yet here is the solution.
The Fuji FinePix S2 Pro uses two sets of batteries one set located in the camera body grip and another set in the battery grip itself. If you are experiencing the problem you are then the batteries in the camera body are dead and need replacement. here is a diagram. Replacing the batteries in the camera body require removing the grip.
Diagram
Jan 06, 2011 | Fuji FinePix S2 Pro Digital Camera
Fuji finepix s2 pro
the lithium batteries power the flash and some of the metering. But if they drop below a certain power, the camera dies. The F33 error is probably the accidental movement of the aperture ring on the lense. If you get the error, check the aperture ring is set.
Aug 11, 2008 | Fuji FinePix S2 Pro Digital Camera
Err message on my S2 Pro
Try removing the lens, the memory card, and the lithium batteries. With freshly charged AA batteries, turn the camera on. If it comes on without the "err" message in that case, your problem lies with the memory card, the lens, or the lithium batteries. Turn off the camera and add these things until you encounter the problem again.
For a lens, check to make sure the electronic contacts are clean and that the lens gets fully twisted into place, and that if there is an aperture lock, that the aperture is set to the smallest possible aperture (22 or 16, usually).
For the memory card, reformat it elsewhere if it is causing problems. The Fuji S2 is notorious for being picky about memory cards.
Lithium batteries that are slightly run-down can cause all sorts of issues. Your S2 doesn't need to use lithium batteries, except for the built-in flash. You can add an extra AA battery pack to replace the lithium batteries, and that will improve the camera's reliability.
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
The Camera Fuji FinePix S2 Pro1 is not starting up
Generally, in indicator on the back display shows empty battery; sometimes after a short a message Err on a display
Feb 24, 2008 | Fuji FinePix S2 Pro Digital Camera
FinePix S2 Pro
replace the cr123 batteries. If one of them is down on voltage you will experience exactly the symptoms you describe.
Jan 15, 2008 | Fuji FinePix S2 Pro Digital Camera
Error msg fuji s2
couple of things:
I take it that "Err" shows on the display ? This can be caused by a number of things, including the aperture ring on the lense being in the wrong position. Make sure its set to the orange number. The 'err' message isnt generally shown for a power problem. If you have a DC power lead, attach that and see if you can get the camera to work.
Batteries are a nightmare for the S2.
Firstly, if looking for rechargeable AA's, you need at least 2300mAh. Maplin are doing a good deal till the end of the month on them; http://www.maplin.co.uk/Module.aspx?ModuleNo=46414
If you have the small lithium batteries in, then take them out. If the camera senses that they are in there, it will try and use them -even if they are depleted.You can replace them with CR123a batteries, but unless you want to use the on-camera flash, I wouldnt bother. DONT BUY RECHARGEABLE CR123A s !! They do not have anywhere near enough power.
Summary; Check aperture ring remove/replace CR123a (High quality replacement) Use high power AA's
let us know if this works
Nov 12, 2007 | Fuji FinePix S2 Pro Digital Camera
Error
Before the heart attack, check your lens. I believe its the D series lenses that need to be set to all the way open. I get this "err" alot, and then look down to see that Ive rotated the appature.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
734 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
