Sylvania model 6319ccc. Set is dead no high voltage.
  • badgolfer88 Jun 14, 2008
    you need a schematic to do this ' which I do not have.
    President:
  • 2,712 Answers
Most likely an issue with the flyback auto transformer, or the power circuitry. You will have to dismantle the TV and probably replace the power board and/or some other components. Best get a qualified repair guy to do this, as I wouldn't recommend a novice to open the set. There are extremely high voltages inside a TV that can KILL, even if the TV is unplugged.
Posted on Jun 16, 2008
    Genius:
  • 1,665 Answers
    Master:
  • 848 Answers
Just replace the smps so that it might get proper power supply
Posted on Jun 13, 2008
    Master:
  • 638 Answers
Try checking the power supply unit of your tv set
  • hemant somaiya
    hemant somaiya Jun 13, 2008
    just check out in your power supply if any capacitors have flowed out replace them if necessary and it wiil be fine.
  • hemant somaiya
    if u are not yourself a technician than dont try it. just call some proper technician reparing charges will be negligible. rate this solution as fixya as this will definately solve your problem.good luck
2 Suggested Answers
SOURCE: Sylvania Tv/VCR combo Model 6319ccc
Hi . The TV that I need help fixing is not a projection TV. It's a 19" or 21" CRT television that has built in VCR. I do not have service schematics so for someone to suggest troubleshooting using schematics doesn't help me. I understood that for $10.00 someone who had repaired the same model would tell me what component they changed out to fix problem. TV is still not fixed. Its a Canadian model so its possible that this SYLVANIA model might not have been sold in other regions of the world. TV also makes slight crackling sound from speaker when you pull the plug from wall outlet.
Posted on Jun 14, 2008
My 50 inch rca tv wont turn on
The set has a shutdown circuit with ties to voltage and current being drawn inside the set--
Common dead set issues include:
broken solder connections at or around the high voltage transformer
Shorted or bad parts on same board as transformer
Bad High voltage Splitter block or the High voltage transformer
Convergence problems which usually do not stop set from coming on.
5_18_2012_2_53_49_pm.jpgtypical high voltage transformer
May 17, 2012 | RCA HD52W56 52" Rear Projection HDTV
Toshiba model#57H94 dead set push power switch nothing want start up dead main ac fuse check good.Sam's Tv Service any help will be appreciate. Thanks
Check hori output and small blue high voltage capacitor 2k that feeds hori output transistor.
If these componets are OK then replace Both of the STK ICs they are big black ICs and will have PN# on them.example STK392-110.
Mats Electronics has ICs 1-800-628-1118
Encompass Parts Distribution has Free Service Manual for this Model# 57H94 you can print it out online.Go to their website.
Jun 05, 2011 | Toshiba 57H94 57" Rear Projection HDTV
High pitch noise, no picture. GE 52" projection, Model D52GW12
Ur high voltage FBT the flyback tranformer,a big black block of plastic with a gray wire connected to a board.The cap it dead.The FBT it useally it dead too,arching noise FBT not holding the high voltage.
Mar 30, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
I can turn the set on but it doesnt put out any picture,and it makes a high pitched ringing sound
Ur high voltage is dead,the FBT the big block of plastic with a red wire hook to a board.That thing is dead.U know how to solders,Website, Tv repair World.com buy the part.
Nov 13, 2009 | RCA HD56W58 56" HDTV
Dead no high voltage 5 red blinks
Hi.
The fault depends on make and model of your TV.
Even on TV from same manufacturer, blinking codes may have different meanings, depending on the model.
Regarding no high voltage, that may be simply because the unit is on protect mode.
On most TVs, when the controller board inside the TV detects a fault, it will shut down all higher voltages on PSU, and it will keep only the low voltage line (often +5V, or +3.3) on to keep unit in standby, and flash the error code.
Nov 11, 2009 | Televison & Video
I have a 42" wide Samsung TV model # hcm4216w which is not working don't know what to do ?
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom.
The only way to determine the real cause is #1 an educated guess based on experience or by directly toubleshootng the set – checking fuses, measuring voltages and checking for shorts.
The educated guess for this make/model is convergence IC’s.
Sep 19, 2009 | Televison & Video
Toshiba Model 42H83 High Voltage Power Board is dead. Where can a new one be purchased and could a person install it themselves? thanks
possibly, the most difficult part is getting the case open usually. Toshiba parts can be souced from the Toshiba support website or a loacl dealer.
Take a pic of the board before you unplug it sop you have a reference to how it was connected. Some models have a ribbon connection in a lock, observer which way the ribbon is up as some have twists incorporated.
Aug 12, 2009 | Televison & Video
Jun 13, 2008 | Televison & Video
Phillips 60'' projection hdtv wont turn on
Question do you see green led or light when pressing power button? If you can also listen for a high pitch noise coming from back of set. This would be an indication that the set has powersuppy problem or high voltage problems. If the set is dead and no noise then maybe fuse or open circuit.
Aug 13, 2007 | RCA P46924 46" Rear Projection Television
No Power
Your set is going into high voltage shut down. Might have been the high voltage transformer that has gone bad.
Mar 09, 2007 | Hitachi 60UX58B 60" Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
