Cannot get colors to converge properly - Televison & Video
  • Anonymous Dec 19, 2008
    colors and shadows of multiple colors along with bowing of the picture
  • Anonymous Apr 22, 2009
    hcn4226wx/xaa
  • 8,617 Answers
You need to replace the convergence ICs. post your model number and I will psot the correct Convergence IC numbers you need as well as where you can get replacements with free instalation instructions with pics so you can do the repair yourself.
Posted on Jun 13, 2008
Convergence of colors
if the colors are out of alignment and wont adjust back properly then you need a convergence repair kit. You can get convergence repair kits with instructions from www.tvrepairworld.com
Feb 27, 2013 | Televison & Video
Our samsung HCl4715W tv is all connected right but our picture is scrambled where you see double exposure and the color is off. Can not find our manual. any suggestions?
The problem of your tv is the convergence. Projection tv set has a 3 colors red,blue and green this 3 colors must be properly lined up to look the video normal. When this 3 colors is not properly aligned the video will produce a double image of color or like a 3d or wavy. In order to fix this problem you should adjust it in the menu program of your tv you should move any of the colors to up or down, left or right if you cannot align the 3 colors the problem is the convergence ic it must be replace. To locate the convergence ic you should remove the back cover of your tv but be sure to unplug your tv, you will see this ic attached in a large aluminum plate it has a marking of stk--- and followed by a numbers. or you could contact a service technician do do it for you and save you from stress. Good day and best regards.
Jul 17, 2011 | Samsung HCL4715W 47" Rear Projection...
On the right side of the screen it is turning red and is not aligning properly looks like it is trying to go 3d. what could cause this?
This tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 23, 2010 | Hitachi 46F500 46" Rear Projection...
The colors aren't lining up properly on my Sony rear projection tv.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 06, 2010 | Sony KP-57WS500 57" Rear Projection...
My tv has lots of red and green. Faces are shadowed by a red outline. It occurs on all channels and dvd.
If problem does not fix by flash focus/ convergence adjustment in Menu then replace convergence output ICs on D board of tv that sounds defective and causing problem.
Comvergence output ICs replacement requires soldering work with proper tools and electronics knowledge/ experience, call local tech if you have no experience.
Jul 16, 2010 | Sony KP-51WS510 51" Rear Projection...
Colors are out of focus and magic focus wont fix
If you have tried the customer convergence menu/control and can not set the convergence you have a fault with the electronic circuit that controls the convergence of your 3 picture tubes this overlaps the 3 colors red, green, blue to create the proper color combination's of colors for a proper picture
May 05, 2010 | Hitachi 57F500 57" Rear Projection...
My Tv has red light (color) out of focus..I've tried tuning the lance but it's not the problem in the lance..it's something else..don't know what..do you?
Your TV has three picture tubes which are aligned to properly converge the projected light beams on the screen. Each picture tube projects a single color of Blue Green or Red. During production your TV was carefully adjusted to properly align these colors. As a feature you have the ability to adjust these colors.thats called convergence.If you don't have a manual to show you how to adjust you can find one here http://www.mitsubishi-tv.com/support.html
Mar 03, 2010 | Mitsubishi WT-46809 46" Rear Projection...
MY COLORS ARE NOT RIGHT, LOOKS LIKE THERE IS NOT ENOUGH BLUE TO MAKE PROPER COLORS. MAY NEED CONVERGENCE COLOR OR CONVERGENCE ADJUSTMENTS. ALSO HOW DO I RESET THE BULB TIMER AFTER REPLACEMENT. THE...
Hi:
There if this is a DLP television there is no convergence adjustment on these models as they are digital. There might be a problem with the color wheel assembly. If this is a Mit's then the optics engine will need replacing, You forgot to mention the make and model of your TV.
Jan 18, 2010 | Televison & Video
The color is off on my tv
you will need to replace the convergence ICs thats what is causing the color not to converge properly.
Apr 11, 2009 | Televison & Video
How to adjust red blue green
if ur in service mode already..turn down all drive.green first turn it up until the desired intensity is achieve.then blue all the way until it almost blend the green.u must not see one color either too much green or blue.turn up red now,let it blend until u see a perfect black and white.note:make sure that the color level is set to minimum and tint to center. ihope i help u..
Mar 20, 2007 | Toshiba 43H71 43" Rear Projection...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
