Question about Fantom Titanium-II (TFD200U2) 200 GB IDE Hard Drive
Won't turn on
Idk what size harddrive i have but it is a fantom and when i start it up it says "found new hardware" but i can't get to it or anything that's on it. what do i do to fix this? i have a ton of important things on there
No i don't know how to do that lol
Posted on Jul 18, 2008
  • 2,794 Answers
If Windows is loaded, unplug the power cord and the USB (or Firewire cable). Turn the power on it. Plug the USB cable back in.
Make sure your drive isn't connected to a USB hub. There are connection problems with those.
Posted on Jun 13, 2008
  • Tim Babcock
    Tim Babcock Jul 16, 2008
    Do you know how to partition a hard drive?
Have recently had to add windows 7 to my PC (losing everything) but have laptop using XP. When I plug buffalo ministation into PC it wants to format but I'll lose everything on harddrive won't
click start control panel administrate tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start then after its finished return and tick the other box you should not
do anything while the chkdsk utility is in progress any input may damage this drive
i have found the best results ticking in one box the returning after it has finished then ticking the other box
it might take some time depending on the size of your disk but be patient
hope it helps
Oct 12, 2012 | Buffalo Technology Buffalo MiniStation...
My external hd (fantom titanium) doesn't regularly open on my mac suddenly
fouad,
Inside the case of that Fantom is a regular harddrive.
Also inside that outer case is a small circuit board, that either the harddrive plugs directly into it; or there is an interface block the harddrive plugs into, and there are wires from it, that connect to the small circuit board.
(The USB cable is connected to the small circuit board)
It is this small circuit board that usually goes bad.
My suggestion is to remove the harddrive inside, purchase an economical external enclosure, and install the harddrive in it.
Have your harddrive back, and be able to use it as an external harddrive again also.
The Harddrive Inside:
Harddrives are measured by their Width.
A laptop harddrive is 2.5 inches across in width. (2-1/2 inches)
A desktop harddrive is 3.5 inches.
The Fantom Titanium II 500GB's harddrive inside, is 3.5 inches,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822204034
Details > Physical Spec > Form Factor > 3.5
What I can't tell you is whether it is an IDE (PATA) harddrive, or a SATA harddrive.
However this external enclosure for 3.5 inch harddrives, is for both IDE, (PATA), and SATA harddrives,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817388014R
[ You can also look at the label on the harddrive, and look up it's model number online, to see if it is IDE or SATA. Just type the model number in your search bar ]
Just want to include information on IDE (PATA), and SATA, in case you are interested,
IDE: http://en.wikipedia.org/wiki/Parallel_ATA
SATA: http://en.wikipedia.org/wiki/Serial_ATA
Regards,
joecoolvette
Jul 27, 2012 | Fantom Titanium II (TFD500C16) 500 GB USB...
Can i put a hdd from a aspire 5610 in to a5580
1) Acer Aspire 5610 series Notebook PC, uses a standard sized
SATA laptop harddrive.
http://www.ebay.com/itm/Acer-Aspire-5610-SATA-Hard-Drive-Caddy-w-Screws-/380170405559
[ Standard size laptop harddrive; 2.5 inches across in width. ( 2 and a half inches, or 63.5mm ]
2) Acer Aspire 5580 uses an IDE (PATA) harddrive, that is standard laptop size.
http://www.upgradecomputermemory.com/ram.cfm//memory/a/Acer/AcerAspire-Notebook-Series/Aspire5580Notebook/80GB-Notebook-Hard-Drive-for-the-Acer-Aspire-5580-Notebook.html
[ Scroll down to the subheading - Interface: ATA-100 ]
It isn't just the harddrive caddy that is different.
The two technologies are different, IDE (PATA) and SATA, therefore the interface is also.
[ Interface:
In this example I am referring to the pin connector, the harddrive plugs into ]
Parallel ATA,
http://en.wikipedia.org/wiki/Parallel_ATA#IDE_and_ATA-1
Serial ATA,
Adapter for the SATA harddrive (5610) to the IDE (PATA ) interface in the 5580 laptop?
Won't work.
1) The technologies are different.
2) There is a Chipset, or more than one, for this bus controller. The 5580 doesn't have a SATA version.
( Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit )
This would make one think, "Hey, I'll just buy an IDE (PATA) 2.5 harddrive."
Nope.
Once Windows Vista is installed it is a 'Bear' to write XP over it.
There is a Correct procedure. This is left to an experienced person.
(Even an experienced tech may have problems)
Also, IF you do get XP to write over Vista, you may be required to Activate again. (Not register, activate)
To explain further;
When Windows is installed on a computer, hash values are assigned to certain major hardware components.
Some examples may be the Processor, Motherboard, Harddrive, and graphics chipset.
More specifically for the Motherboard, it is the motherboard chipset, and the BIOS program. (Version and date)
Change any two of these hardware components, and Windows may want to be activated again.
Suggest new IDE (PATA) harddrive for the 5580, and use the Restoration Disk.
Don't have one?
Computer manufacturers stopped including a Restoration CD Disk.
(I do believe they have started again, though)
Many users felt uncomfortable trying to repair their computer, took it to a shop, and never bothered using the disk.
Many lost the disk.
Let's say the disk cost around $1.
Take that times 50,000 computers or so. The computer manufacturer is saving money, not including a disk the majority, seems to not want to use.
The computer manufacturers started including a restoration partition, on the harddrive. (That's nice unless you have graphics problems, and can't see what is going on)
When the computer is new, and the owner starts the computer for the first time, there is a pop up asking if you wish to make a Backup.
THIS, is your Restoration Disk.
The new owner is ONLY asked ONE time. If the owner clicks on 'Never show this again', the opportunity is GONE.
What to do?
New IDE (PATA) harddrive, see what it costs a shop to put Vista (Same version) on it.
OR,
Buy a new Vista, or Windows 7 genuine copy, and install it.
HOWEVER, before trying to install Win7, make SURE there are drivers for Win7 available.
If not, DO NOT install Win7.
(Microsoft makes ONE master disk of an Operating System.
{ And version } From it all GENUINE copies are made, and sold to the consumer )
Summary:
1) New IDE (PATA) harddrive
2) Have Vista installed, or see if drivers are available, and install Win7.
For clarification on anything I have stated, or additional questions, please post in a Comment.
Regards,
joecoolvette
Feb 10, 2012 | Computers & Internet
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
N800v harddrive blew out
It depends upon your needs, the larger the hard drive to higher the cost and the maximun size you can install depends upon the BIOS. The smallest hard drive that is readily available is about 100Gb.
Jun 15, 2009 | Compaq Evo N800v Notebook
Fantom 120 gb external usb harddrive
Make sure you are using the right power unit, or the power unit is working.
May 13, 2009 | Fantom Drives 120 GB Hard Drive
Error msg cannot start correct harddrive not found
Your hard drive has died. You must replace it. Get any size SATA 2.5" notebook hard drive replacement and install it. I have seen this issue plenty of times. Usually on the old 40GB systems.
Feb 11, 2009 | Sony Playstation 3 (PS3) Console
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
Fantom Titanium-II (TFD200U2) 200 GB IDE Hard Drive Logo
142 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
