Question about Ricoh Aficio 250 Copier
Our copier is printing copies with a black band
  • MSM Nov 04, 2010
    line when copying off the glass or through doc feeder? if doc feeder clean **** glass
    print off the meter reading is the line still there? if yes sounds like pcu (drum) or hot roller gone
  • 126 Answers
The drum unit is faulty. i think the cleaning blade needs replacing.
Posted on Nov 05, 2010
I get a thick vertical black line/margin down the entire page when i scan on my SX115
Please make sure the scanner flatbed is clean.
You can also try to copy and see if it happens on copying.
If it does, then your printer needs servicing.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Horizontal black bands on copy
i would recommend you call a service technition on this problem.... it could be several things, the corona wires need replaced, the fixing assembly might need to be rebuilt, and or the drum might need cleaned and or replaced
May 21, 2010 | Canon NP 6050 Copier
Copying black but it is only printing in bands with white bands throughout.
Your print head is probably clogged. You need to go to "start", then "settings", then click on "printers and faxes". Right click on your printer, then click on "properties". A window will appear with several tabs. Go to the last tab named "maintenance". You have several options, but the one you need is "deep cleaning". Click on that and follow the instructions. You might have to repeat the process several times in order to get a satisfying copy. I also have to warn you that cleaning the print head uses a lot of your ink, but it should solve the white bands issue.
Apr 01, 2010 | Canon PIXMA MP780 All-In-One InkJet...
One inch black band with copying
I think the scanner has crud or dust on the reader. You likely want a "pro" to clean it.
Jan 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
A black line is appearing on the printed paper on all copies.
Hello.
check the Fuser unit "the two roller" .... are they clean?
Jan 12, 2009 | Panasonic FP-7735 Black and White Copier
Lighter bands across copy using Canon F 132500 copier
Open the flap to expose copy platen and press print you should get a flat even black
if you get the white bands do the following:
Clean the corona wires open the cover pull out the sliding charge wires and clean with q tio and acoho or a pencil erasure
If that does not work remove top glass and clean mirror and bottom of glass
Dec 24, 2008 | Office Equipment & Supplies
Grayscale printing problem
Try printing from different application if it still doing the bandings on other application, tell me. Thanks
Apr 07, 2008 | Office Equipment & Supplies
Streaking
hi im jules_09.his there any error code?if no error code try to adjust the voltage on the exposure lamp,if that does not work can you send me a sample print at cmhal_09@yahoo.co so i can see the print .
Oct 14, 2007 | Toshiba 2060 Copier
Ricoh Aficio 250 Copier Logo
32 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
aaron douglas
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
