Question about FAIP Non Marking Pressure Washer Hose 4000 Psi, 50ft. Length
I have a Craftsman Power Washer model 580752300 and want to replace the pump. The curent pump is item # 189970GS which I don't believe is available any longer. Can you suggest a replacement pump?
Location of pump oil input valve
Hi
Im surprised that this model pump has a oil refill. Most pumps of this size arent refillable. This looks to be a pump made by FAIP. Its an ok pump but I would recommend using it until it fails and then replace with an AR RMW pump. Much easier to get parts for. Here is a diagram of your pump...The oil refill plug is on the side of the pump...that is located under your engine. You want to get the recommended oil for your pump. Most pump oils are 30 weight non-detergent but these small pumps take an oil specific to only them. So follow your specs...your diagram is here http www searspartsdirect com Craftsman Power washer Parts Model 580752330...
and your manual is here 580752330 CRAFTSMAN PRESSURE WASHER Manual
Hope this helps
Sep 20, 2014 | Craftsman Garden
How do i replace water intake line on craftsman powerwasher model 580.752070
https://www.walmart.com/search/?query=190588gs&&adid=22222222224329855348&wmlspartner=wmtlabs&wl0=e&wl1=o&wl2=c&wl3=74629383116912&wl4=kwd-74629453980726:loc-190&wl5=65542&wl6=&wl7={loc_interest_ms%20}&wl14=190588GS&veh=sem
This piece can be replaced. Google model n.umber for parts breakdown. then google part number. prices vary from $75 -$52
Jul 29, 2017 | Craftsman Garden
I purchased a used Craftsman 2 HP 20 Gal air compressor, model # 919.176220. I'm looking for a copy of the user manual, Sears # SI-30-14-4-C. This item is no longer available from Sears.com and doesn't...
Since the exact model number manual is not available go to Sears and look at the compressors they have on the floor (or in the catalog). Find one that looks like the one you have and note the model number (these devices haven't changed much over the years). order the manual for the one that matches your machine the best.
Mar 22, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
I need a piston stop part#4357.00 craftsman 16 gauge finish nailer model # 351.183210, im told by sears part is not available, any other finish nailer with the same part?
same thing here, I believe it was made by porta cable looked at their nailer, looks the same trying to get that part should be around $14 plus shipping
Jul 29, 2010 | Craftsman Garden
I need replacement remotes for garage door opener Craftsman 139.53681b What is the # for the current replacement item
The Craftsman number is the same as you have without the b. You can find it at Sears parts but don't put that number in the model search. Use the part search. It is available.
Dec 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Hole in pump caused by coin -- causing flooding
There is no screen! I bet it was a dime that was caught in the pump. It has happened to me several times to the point where we double check all pockets when loading washer. Coins larger than a dime stay in drum or in lower basket. Poor design! I now leave the back of washer loosened and have mastered pulling hose off the PLASTIC pump housing and reaching in to pull out the coin.
Apr 06, 2009 | Kenmore Oasis HE 27062 Top Load Washer
Front load washer
look for a sock, or other small item in the pipe to the pump, more common than than you would believe.
Exactly how to access the pump on your washer is dependent on model
Oct 13, 2008 | Washing Machines
Craftsman Pressure Washer Model #580762250 Serial # 4033531 Need a manual for this particular machine. When it builds up pressure it cuts off.
I believe sears will give you one free;
http://www.managemyhome.com/mmh/lis_pdf/OWNM/98070390.pdf
you have to download it, but it isn't too much trouble, page 16 lists a whole laundry list of possible problems. Word of advice, change your oil in the pump regularly, if it is burnt appearing you might want to consider replacing rings etc and complete teardown, we didn't and trashed the pump.
Jul 11, 2008 | Electrical Supplies
Open Questions:
See all FAIP Non Marking Pressure Washer Hose 4000 Psi, Questions
FAIP Non Marking Pressure Washer Hose 4000 Psi, 50ft. Length Logo
206 people viewed this question
Top FAIP Garden Experts
roeb
john h
Marvin
Marvin
Are you a FAIP Garden Expert? Answer questions, earn points and help others
