Question about LG DLEX2501 Dryer
During the steam cycle, some water leaks out onto the floor from the bottom of the door. Is it ok to use dryer sheets in the dryer?
  • 210 Answers
SOURCE: water leaking out of bottom of door
There is a rubber seal that runs along the bottom of the door. If you carefully run your hand along there just to see if it is all even. Sometimes they get out of place and you can push it back and then closing the door it realigns itself and all is good. If the seal is damaged, you have to replace the door liner as the seal is attached.
Sgt 48
Posted on Jun 07, 2008
  • 423 Answers
SOURCE: Steam coming out near bottom of door causing water to pool
Steam coming out is not normal and you should get it serviced soon. While not dangerous, it probably means that water is leaking inside the door panel from the "Hybrid Drying System" that is a feature which LG uses/touts. Other disheashers use a conventional condensing drying system.
The moist air enters through the internal drying system in the door panel, dry air is added from the outside air with the help of a fan and that air is routed though ducting down to the bottom of the door.
That system is clearly broken. If you have more questions on this, please reply. Good luck!
Posted on Mar 29, 2009
  • 423 Answers
SOURCE: leaking from the dryer vent on base of door during
Before try to repair, gather the model and serial number from the unit and contact LG support line. There was a recall on early versions of the (energy saving) condensing drying cycle and specifically most of the components in the door.
If the problem is what I described above, this is not a warranty issue but a product defect/recall. Be firm with them, be polite and do not take no for an answer, asking to be "escalated to the phone guy's supervisor:"
Good Luck!
Posted on Sep 15, 2009
SOURCE: LG dishwasher is dripping water from vent onto floor
I have steam coming out during dry cycle wetting my floor. What is the kit that LG has developed and where can I get it?
Posted on Apr 27, 2010
  • 66 Answers
SOURCE: water leaking from bottom of LG french door freezer on bottom
yep, total defrost is the 1st thing to do. if you want to speed the process, see the following page how to do is good luck
Posted on Jan 29, 2011
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
Whirlpool duet dryer stuck on steam cycle
one trick to stop the steam is to remove the water hose connected to the dryer
Nov 20, 2013 | Whirlpool WED9500T Electric Dryer
Floor wet in car rain
remove the door trim of the side that has the wet floor and replace the plastic membrane that should be stuck over all the openings in the inner panel. Ensure that the drain holes at the bottom of the door are open and clean and not blocked up.. Because doors are curved the water runs to the bottom of the glass and drops onto the plastic sheet that keeps the water in the door . If the sheet is missing or is not sealing the openings then the water goes to the inside of the panel and leaks inside the door onto the floor.
Nov 01, 2013 | Mazda Cars & Trucks
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Model # GSH22VGPC CC water leak
Evaporator condensate should go to pan for evaporation. If the amount exceeds pan capacity during defrost cycle it could overflow to the floor.
Sep 03, 2017 | GE Refrigerators
Hi, have have 21' Bottom Freezer refrigerator, model 69142992. My bottom freezer is getting a sheet of ice on the bottom, where the basket becomes frozen in place. The the freezer leaks water onto the...
hi dear you have to unplug ur ridge and then open the freezer door remove the food try to defrost the ice by a hair dryer then remove the basket boil some water and pour it on the white metal back inside the freezer tell you feel the water goes inside ,your problem is drain blockage ,or stop the fridge for 24hours and it will work normally
Sep 11, 2010 | Kenmore Refrigerators
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
Mar 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Oct 23, 2006 | Maytag 24 in. MDB4000 Built-in Dishwasher
LG DLEX2501 Dryer Logo
357 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Craig Butler
Craig Butler
Are you a LG Dryer Expert? Answer questions, earn points and help others
