Question about Brother IntelliFax-2920 Plain Paper Fax, Copier and Phone , 33.6 Kbps Modem Laser
I have a intelifax 2920 Super G fax machine that has lines horizontally through the page, just one every 4 inches on the pages that are faxed in
  • 1,110 Answers
This is a drum defect. You are going to have to replace the drum unit. I have seen this so many times I have lost count. The drum unit is the part that your toner cartridges are installed into. Just order one in and replace it. The lines will go away.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Nov 04, 2010
Testimonial: "We will see!!!!!!!!!!!!!!!!! Thanks!"
I have a Brother Intelifax 2820 that when you fax anything it puts a black line down the middle of the page. I have taken a soft dry cloth and cleanded the corona wire and that didnt seem to help.
the corona wire, which is on the drum unit only comes into play when you are receiving faxes. if i read right and its only on sent faxes, you need to clean the scan glass. that is located underneath your control panel where your originals to fax out get fed. open up your control panel and locate piece of glass that goes left to right across machine. clean that good as you probably have white out or something similar on that.
hth,
razors
Sep 21, 2011 | Brother IntelliFax-2820 Laser Fax
My faxes are being received as blank page, why?
make sure the faxes you send are face down in the feeder, if you can read what you are sending they will be sent blank
Aug 17, 2010 | Brother IntelliFax-2920 Fax
Fax-2920
If you can send a fax and receive a fax at any point, your fax machine is running perfectly. There is a phone line problem somewhere
Jul 04, 2010 | Brother IntelliFax-2920 Fax
Line goes through page when fax is sent
Open up the document feeder and clean the small glass. If the line is more than 1/4 inch wide you have a bad scanner block.
May 13, 2010 | Brother IntelliFAX 2800 Laser Fax
Our intelifax says memory is full and I do not know how to clear it so we can receive faxes
This page has instructions for entering the Maintenance Mode, and for clearing memory. Note that you should only need to use the "91" clear method. The "01" method is for when the machine's memory is thoroughly messed up, or if you're selling the machine and want it to go out the door a blank slate.
Feb 17, 2010 | Brother IntelliFax-2820 Laser Fax
When faxing out-2 large black horizontal lines appear on page
Bad scanner block, sorry. Very expensive if you can find one.
Mar 11, 2009 | HP 1040 Plain Paper Inkjet Fax
Dark Horizontal Lines on Faxes
on the drum unit that you put your toner inn, There is a blue or green slide lever move the slide back and fourth 10-15 times. If you have some van air blow that area out ( F.Y.I. if you do this some toner will fly out ) if this does not take care of it the drum unit my be bad,
do a 1/2 print test. copier something with a lot of print. open front cover when the paper is 1/2 way through the machine remove drum. Look art the paper and the green drum if the marks are on the paper & drum then the drum is bad. If not the fuser asm is bad, the part that gits hot when melting the toner on the paper,
Jan 29, 2009 | Brother IntelliFax-2820 Laser Fax
Brother FAX-2920 sending-receiving problems
Make sure you are plugged into the LINE port of the fax machine.
Oct 22, 2008 | Brother IntelliFax-2920 Plain Paper Fax,...
Minolta Fax 3600
Yeah, pretty much s(****). That message means the polygon mirror in the laser unit is not spinning up.
If you want to try to fix it, it's a square black box under the top covers. You can take it apart and oil the mirror shaft.
Sep 07, 2008 | Office Equipment & Supplies
Brother Intelifax 2920
this sounds trivial but when you changed the toner did you follow the instructions that were included in the box?
Brother machines have to be doen a certain way or the page count on the cartrigde will not reset and will still say low/empty etc
Hope this helps
Pete
Pete@wedotoners.com
Dec 06, 2007 | Office Equipment & Supplies
Brother IntelliFax-2920 Plain Paper Fax, Copier and Phone , 33.6 Kbps Modem Laser Logo
220 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
