Question about Alpine CDE-9841 CD Player
It won't Start
Hi i just install an used alpine cd player 9841 into my 91 sentra. its all wire correct and now the cd player wont turn on.
It was working before i took it out from my sister car.
so how do i fix this problem.
thanks
  • shytbag Jul 28, 2008
    installed it and it turnd on and the radio worked. i went to put a cd in and it clicked 3 times then shut off and wont turn back on. All fuses are good, and the wiring is perfects. My friend had this before i did and everything worked. Do I need a remote?
    Problem Solver:
  • 6 Answers
Remove the head unit from the rack. you will find a fuse at the rear. I might have lown. Replace with a new fuse and place in the rack. Now it should be good to go.
Cheers
Alex Victor
Posted on Nov 10, 2009
Hi there I have alpine cda 9856 cd player and it turns on and does every normal however it won't output and sound on either radio or cd. I have checked for any bad connections and can't seem t
Did you make sure you have no shorted or grounded speakers or speaker wires? Make sure you don't have a bad speaker also. If everything checks out, you may have a bad internal output ic.
Jan 15, 2013 | Alpine CDA-9856 CD Player
Installed new cd player and it wont power on
this happened to me in one of my cars, I bet that if you put the factory radio back in it will work just fine, most of the radios components, are part of systems wiring and used to send signals to ecm to let car start
Oct 07, 2012 | 1999 Chrysler Concorde
I just installed my lightly used alpine cdA 105.the radio plays on all speakers but when I try the cd or iPod it only plays on one speaker. Any thoughts.
are you using an amplifier? if so, you may be using the blue wire (antenna remote turn on) instead if the blue/white wire (amplifier remote turn on) to turn the amplifier on. the antenna remote turns off when leaving tuner mode.
Feb 15, 2011 | Alpine CDA-105Ri CD Players
My alpine cd player said error and now it wont put out sound
if you spliced the wires then two of them may have touched somehow this will cause a short out to the speakers and to the deck take it out and check the ground constant and all of the speaker wires to make sure that they are all seperated and connected correctly.;
Jun 03, 2010 | Alpine CDA-7894 CD Player
Dont know where black wire pluggs in
A black wire is a ground wire and most likely it should be connected to a good ground source like the metal support for the dash.
Apr 28, 2010 | Alpine CDM-9821 CD Player
Alpine cda 9884 has no sound in cd or ipod mode
actually, chrysler/dodge has factory Infinity sound systems installed. The nice part about these systems is that you dont have to bypass the amplifiers in order to put a new radio in, but simply power up the amp by hooking up the amp turn on wire at the harness. The alpine should have 2 blue wires coming off of the back, one that is solid, the other with a white stripe. The one that is solid only has 12v when the fm/am radio is on (used for power antenna) but cuts off when other sources are used (cd,aux,ipod). My guesses are, you have the amp wire on the vehicle harness (blue) tied into this wire, instead of the BLUE/WHITE wire on the alpine which has 12v as long as the radio is on. i hope this solves your problem, 9 times out of 10 on a chrysler this is it.
Auto Tech
DA2 (Supa)
Jun 07, 2009 | Alpine CDA-9884 Car CD/ MP3 Player
Alpine cda-9811 is not accepting amp as external amplifier?
The signal should go from the head unit to the amp to the subs. Someone must not have wired the subs correctly through the amp, or amp to the cd player..
Jul 08, 2008 | Alpine CDA-9811 CD Player
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
No sound (Alpine CDA-9826)
Is this a new installation or did it just start happening without anyone changing any wiring? If it is a new installiation make sure you have the remote turn on connected to the remote turn on wire from the radio(blue and white) and not the power antenna wire (blue). The blue wire will turn off when you switch to cd while the blue and white will not.
Aug 12, 2007 | Alpine CDA-9826 CD Player
Alpine CDE-9841 CD Player Logo
101 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
