Question about Lexmark X4270 All-In-One InkJet Printer
UNALBE TO RECEIVE FAXES
HELLO,
I AM HAVING A PROBLEM WITH MY ALL IN ONE. I CANNOT RECEIVE FAXES (unable to connect - it says). WHAT STEPS SHOULD I TAKE TO TRY TO FIX? I WOULD GREATLY APPRECIATE ANY HELP YOU COULD GIVE ME.
THANKS & BEST REGARDS,
LUISA SCHULZ
  • pureone Jun 17, 2008
    Please HELP!!! I have the same problem I cannot send or receive fax. Thank You.
  • LUISA Jun 20, 2008
    THANK YOU SO MUCH. I LOST MY MANUAL AND FORGOT ALL ABOUT THAT. THANK YOU, THANK YOU, THANK YOU.
  • 48 Answers
Problem Receiving--
Make sure ur answering Mech rings are set more than the fax mech...i.e (if ur answering mech is set to 3 then fax mech should be set to 4)....
If u r using DRPD(distingtive ring pattern i.e If u have one line and two numbers.....) then set double ring for fax and single for Phone or answering mech....or vice versa...
Posted on Jun 19, 2008
Hello, I have an HP Photosmart C6180 All-in-One Printer, Fax, Scanner and Copier. It seems that as soon as I turn it on a message comes up: "Fax Failure" Unable to Send or Receive Faxes" This message has...
try ti perform steps as ---->Disconnect the power cable from the back of the printer and then press the power on button for 3- seconds and then at the same time connect the power cable at the back of the printer and then try to turn on the printer and then try to make copy from the printer
Aug 19, 2010 | HP Photosmart C6180 All-In-One InkJet...
Unable to receive faxes on HP Photosmart Premium
Check the configuration set for incoming FAX and rectify the settings may resolve your problem.
Thank you for using Fixya.
Jul 22, 2010 | HP Photosmart Premium C309A All-In-One...
Able to send faxes but unable to receive faxes.
You probably have to set something up in your settings.
Usually this goes: Settings>Fax Setup>Receive
Of course, this is generic, and all Fax machines are different. Is there a model number?
Jan 15, 2010 | Compaq Office Equipment & Supplies
Unable to receive faxes. Able to send and cartridge printing OK
There can be a few things wrong lets take it step by step
1)Receive mode,your receive mode must be set correctly.If you don't have a tel connected to it, you cant use it as a Manual receive mode,it must be set on Fax only.If there is a telephone connected to it and it is set on manual mode make sure your Incomming ring is set to ON,you will find it under additional functions,RX settings,Incomming ring.
2)Make sure you have enough memory to receive a Fax.Go additional function,dataregistration,TX settings,Erase failed TX,set it to on.
3)Make sure there is enough toner and paper for the machine.
4)Tone or Pulse Dialing,depents in witch country you are make sure it is set correctly Tone or Pulse.You will find it under user settings.
5)There can be a problem at the you local exchange,you can send faxes but the exchange can be faulty and you would be able to receive faxes.
6)And then there can be a problem with you fax machine' NCU PCB board,there is to gas arresters one for send and the other for receive.If one of them are faulty you will have to replace the NCU.The gas arresters is not available as a part.
Dec 09, 2009 | Canon FAX-L360 Plain Paper Laser
Can send faxes but cannot receive - shuts off after 2 rings
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
Apr 19, 2009 | Lexmark X4270 All-In-One InkJet Printer
Can't Receive Faxes
Promotional faxes are coming through fine everyday. However, we can not receive any of our business faxes. No changes have been made to the fax. Please Help ASAP.
Aug 14, 2008 | Canon FAXPHONE L80 Laser
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Fax problem
Check your preference settings and make sure the fax is set to receive faxes (my friends has 6 different settings) Your manual should tell you how to do this. The default is different for many fax machines.
Jan 02, 2008 | Lexmark X4270 All-In-One InkJet Printer
IT will not print.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. OR A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. OR If faxes are present, you can transfer them to another fax machine. Go to Step 3. OR You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. OR To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X4270 All-In-One InkJet Printer Logo
163 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
