Question about GPS
Cooler and warm box, damage motor and fan where to get replacement parts?
    Top Expert:
  • GPS Master
  • 84,027 Answers
Since it is obvious this not a GPS please provide the make and the model and i will try to assist you with a source for parts.
Posted on Nov 04, 2010
The fans in my cooler stopped working. how can I fix, or replace them ? I have an DCW283BLS Model
There are 3 fans in this unit. One high up in the back panel for defrost (which should seldom run), and two inside the box with the LED's that divide the compartment into upper and lower areas. All are interchangeable. Replacement parts are available through Sears Parts Direct.
If you intend to do the repairs yourself, make sure the cooler is unplugged when working on it. To gain access to the two fans in the divider box, remove the wine racks to give you more room, and just remove the four screws holding the top of the divider box on and lift it off. One of the fans is directly behind the PC board and the other is inside the 8x10 foam box to the rear of it. Be careful with this foam box, it is delicate. To gain access to the fan inside, use a thin bladed knife or razor blade to delicately separate the top from the sides.
Before replacing fans, try tracing the leads from the fans to the PC board and swapping the plugs for the fans on the PC board and plugging the cooler back in to see if any of the fans are working. Make sure you restore the plugs to their original positions. If all three fans are not working, the problem may be the PC board or the thermocouples.
Mar 15, 2014 | Danby DWC283BLS Wine Cooler
Need to no how to replace a radiator
Remove the hoses and transmission cooler lines. Remove the radiator retaining bolts and dis-connect fan control wiring. Remove radiator and fans together. It is possible to remove just the radiator but you risk damaging surrounding parts. "O" I almost forgot by a box of bandages.
Mar 14, 2013 | 1994 Buick LeSabre
Looking for a replacement motor for coleman thermoelectric cooler. Where can I look?
You can find the replacement motor here
Replacement Fan Motor For Coleman coolers
You need a set of basic tools including wire crimpers, cutters, soldering iron and solder and shrink wrap tubing.
Aug 31, 2010 | Coleman Electric Cooler 40 Beverage Cooler
NEED PART NUMBER FOR THE FAN ON A COLEMAN POWER CHILL ICELESS 12-VOLT COOLER.
Visit the Coleman replacement parts web site.
www.coleman.com/coleman/parts/PartsDefault2.asp
Jul 19, 2010 | Electronics - Others
Fan top back of unit is on and off continuely and making noise as in a failing bearing. I have removed the retaining screws, however the wiring has no disconnect to permit removal from the fan. Otherwise...
Unplug unit. Find name plate info on back of fan. It may be a 6 watt stamped CW. The rotation on small watt motors is based on looking at it from the "lead" end or rear of motor. You will have to cut the cord, WHEN UNIT IS UNPLUGGED. A new fan motor can be connected to the old cord with wire nuts. Install old blade on new fan motor.
Nov 02, 2009 | Danby DWC283BLS Wine Cooler
The outer fan dont work. where can i get a replacement ?
Check at your local computer/ Hobby Electronics parts store.
Take the fan out of the unit and to the store with you, that way they can match it to one they may have in stock.
Sep 14, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Coleman Electric Cooler doesn't stay cold
the most common problem is that one or both cooling fans has failed. If you have the newer version, you can get replacement fans anywhere computer parts are sold
Jul 03, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Coleman 12-volt cooler stoped working/fan burned out
Sound like you have the newer version. These fans can be found at Radio Shack or anywhere computer parts are sold. It doesnt have to be an exact replacement. Just big enough to fit over the Cooling fins. Also make sure it's a 12 volt motor
Jun 25, 2009 | Coleman Electric Cooler 40 Beverage Cooler
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
GPS Logo
13 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
