Question about General Cycling
My son has the Hummer H20 bicycle and the rear brake is broken the wiring completely came out from were you apply the brake on the handle bar.
  • 740 Answers
SOURCE: rear brakes wont apply consistantly
BAD proportion valve.
Posted on Jan 08, 2009
  • 71 Answers
SOURCE: rear bicycle wheel won't turn. Brakes are siezed.
Find the arm that hold the cable. Loosen it to the desired tension.please comment if it does not work for you! I can help! Good Luck!
Posted on Jun 11, 2009
cogdoc
  • 7 Answers
SOURCE: how to raise the handle bar in huffy 14
The silver bolt on the neck behind the handlebars. Losen it off a few turns, and the entire stem can be raised and lowered. Be sure not to raise it too much, should be a minimum mark, or else leave a good inch or two still in the frame, and tighten it back up. Make sure it's aligned with the front wheel though!
Posted on Jul 01, 2009
  • 8404 Answers
SOURCE: the housing of my brakes on the handle bars is
If the screw is all the way tight and still slipping ... try to find a fatter part of the handle bar to mount the grip to. You will probably will not find any such that is convenient for you to continue to use the brake ... remove the grip, wrap some electrical tape around the handle bar, reattach the grip. Tighten it and give it a try.
I hope this works for you
a
Posted on Oct 12, 2009
  • 2309 Answers
SOURCE: I have a 1980 suzuki gs 1000, the problem is, that
check the ground to the taillight
Posted on Oct 27, 2009
How do i thread the brake cable through the handle bar the nipple will not fit through the barrel
Remove the cable from completely and thread it through from front to back.
Jun 24, 2012 | Cycling
Broken brake cables
There are two different brake cable ends, one is for road bikes, the other is mostly on bicycles with flat handle bars. Brake cables generally need lubrication and adjustment. It is not uncommon for corrosion to develop inside the bake cable housing. I would appreciate more information on your broken cables. The cables are not expensive and are easy to replace.
Jul 06, 2011 | Cycling
My sons handle bars are loose, so everytime he turns the steering is out of alignment, this is a bmx bike, the brake cables go into the frame, how do i tighten it so he can ride it?
There should be a single hex head bolt on the goose neck that is the thing that the handle bars go through. Tighten that hex head bolt and you should be good to go.
Sep 18, 2010 | Huffy Cycling
The housing of my brakes on the handle bars is loose and keeps moving. how do i tighten it so that it stops moving when i apply pressure on it and/or squeeze the brake lever??
a
Oct 12, 2009 | GMC Denali Road Bike
Trouble with back brakes/cable?
The brake line for the back seems to be stuck, make sure it's tight on the handle bar and the brake in the back is not overly worn or too tight. If the problem presists try replaceing the pads and brake line.
Jun 18, 2009 | Cycling
Brake assembly
If you loosen the wire that is connected to the gripping machanism first , you will have long enough wire to put it throu the brake grip first then tighten it back at the wheel gripping area.
Dec 01, 2008 | Huffy Disney Princess 16 in. Girls Bicycle
Brake Problem
hi im dave
hope i can help
when you had the rear pads applied and the discs turned was there noticeable damage to the disc surface it sounds like your e brake cable is not adjusted properly or perhaps the braided wires inside the insulation are seperating along your brake cable causing the rear brakes to not be adjsting themselves properly. Every time the parking brake is applied the rear brakes are self adjusted if they arent being applied due to slack in or a broken cable you will not adjust your rear brakes. This would accont for the flutter in the brake pedal as hydraulic fluid is still circulating to compress the pads against the rotor but the pads arent reaching the rotor.
Jun 22, 2008 | 1998 Mazda 626
Cycling Logo
192 people viewed this question
Top General Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a General Cycling Expert? Answer questions, earn points and help others
