Question about Hoover U6476-900 WindTunnel Vacuum
Brush not turning
Brush is not turning, any suggestions?
  • tracyandwill May 20, 2009
    I removed the brush cover and inspected the belts. Both belts are in good condition. The drive wheel iand large belt are turning but smaller brush belt is not being engaged.
Check belt to see if it's ok, you may also wish to remove brushroll from vacuum to make sure it turns freely before putting on a new belt.
Posted on Jun 13, 2008
I put a new belt on my vacuum and right away it broke
There may be a problem with the brush roller itself. When the belt is removed and you have the brush in your hand, make sure that you can turn it.
If the brush turns fine, what I suggest is put another belt on, and before you close it up, turn the brush with your fingers. The brush should turn. If not, and I have done this myself before too, the belt may have been caught under the brush and not able to turn at that point.
When you get it closed up again too, before plugging it in, give the brush another turn. Just make sure that it is not pinched by the lower housing too.
Good Luck,
Mark
Nov 08, 2010 | Bissell 3576 CleanView II Bagless Upright...
THE ROLLER BRUSH WILL NOT TURN. I PUT ON A NEW BELT AND IT BROKE IMMEDIATELY. THE ROD THAT HOLDS THE BELT IS MOVING BUT THE BRUSH IS NOT MOVING.
Apparently something is binding the brush, keeping it from turning. Remove any string, hair, etc., that is wrapped around the brush. Removing the brush is the easiest way to do this, then cut the material through at one point.
While the brush is out, check the ends for signs of damage that may cause the brush to bind. Also, check the area the brush connects to.
Reattach the brush and try to spin it. If it spins freely, put your vacuum back together, with another belt, and try again.
If this doesn't work, I suggest a new/different vacuum.
Oct 25, 2010 | Bissell Vacuum - Momentum Cyclonic 1 ea...
Hi, The belt of our Dirt devil bagless vaccum broke and we got new belt and replaced it. Even after replacing the belt, the brush is not rotating. Any suggestions please ?
Did you check to see that the beater brush, the brush that the belt drives, is free of debris and moves freely? When they bind up they can cause the belt to break. Remove the beater brush just as you do when changing the belt and clean as best you can. There are retainer clips at each end of the brush, add some WD40 between the clips and the beater brush and turn by hand to free it up. Reassemble making sure the belt is on in the proper manner so that the brush will turn in the correct direction. If you find this solution helpful, I would appreciate a Thumbs Up from you!
Thank you. Paul
Oct 06, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Belt will not turn
If the belt is connected and not broken, then the brush that it drives is suspect. Remove the brush and clean as best you can. At the ends of the brush spray a bit of WD40 and twist by hand until it moves freely. This solves about 95% of the brush issues.
If you find this suggestion helpful, I would appreciate you leaving a rating for me. Regards, Paul
Sep 24, 2010 | Hoover U8181-900 Savvy Upright Vacuum
I have the ultimate g kirby. the green the brush doesnt spin when i turn it on and the belt is on correctly. whats the problem
You will find videos at this site that might be of help to you.
http://www.kirby.com/Portals/0/videos.html
If the brush does not spin you probably should remove it and clean well. Also, on each end of the brush you will find a holder that keeps the brush in the unit. These should turn freely around the brush. If they do not, clean and add a bit of WD40 then manually spin the holders around the brush and reinstall.
Please contact me if these suggestions do not work for you.
Paul
Sep 18, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Actually have model 6594. no suction. any suggestions?
If you hear the motor running and the vacuum is not sucking up debris, I would believe you have a problem with the beater brush. Problems with this brush are usually caused by 1 or 2 if not both of these problems: 1- The drive belt for the brush is broken. 2- The brush itself is frozen due to debris. Remove brush and clean all debris off. Pay special attention to end pieces of the brush that hold it in the vacuum. The brush should rotate around these two pieces. Clean ends and spray on a little WD40 and turn to work it so that the brush turns freely. If you find the brush is frozen and needs to be cleaned, probably a good idea to put a new belt on at the same time. Be sure the belt is put on correctly so the brush turns in the proper direction. Feel free to contact me if you have questions.
Sep 17, 2010 | Bissell 6596 Bagless Upright Vacuum
I can not get the new belt to rotate on my vaccum. The roller will not turn when it is put back in place. Any suggestions?
If by roller you mean the beater brush that the belt is attached to, you might try taking the beater brush out of the unit and clean both ends. There should be some kind of plastic or rubber holders on each end of the beater brush. The brush itself is supported by these holders, but the brush needs to be able to rotate in the holders. Sometimes they get gummed up and need to be cleaned in order for the brush to turn freely. Clean them up, apply some WD40 and make sure the belt is properly attached. Hope this helps.
Aug 29, 2010 | Vacuums
The brush won't turn. Any suggestions?
not a expert just trying to help,, check and see if brush turn by hand,, if so take bottom plate off and check belt to see if it is broke,,hope this help you
Oct 20, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Aug 23, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover U6476-900 WindTunnel Vacuum Logo
114 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
