Question about Apex Digital LD4088 LCD TV
Turn on Tv and no sound - Apex Digital LD4088 LCD TV
  • 62 Answers
You need a main board . sound is produced on the main.
Posted on Nov 04, 2010
  • Anonymous Nov 04, 2010
    you need a main board and the part# is on the board use google to search for the part.
My Vizio gallevia 1080 progressive liquid crystal hdtv has no sound-see details for question/detail..
Here are the most common reasons you may not have sound.
Starting with the most common solutions for no sound from TV:
Television Has No Sound Answer 1: Make sure TV is not muted.
Television Has No Sound Answer 2: Make sure the TV is not set to SAP (secondary audio protocol)
Television Has No Sound Answer 3: Make sure TV input is correct (someone may have accidentally pressed the "aux" input button or similar causing the TV to use an input with no sound going to it)
Television Has No Sound Answer 4: Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.
Television Has No Sound Answer 5: Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)
Television Has No Sound Answer 6: If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.
Television Has No Sound Answer 7: Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.
Sep 28, 2016 | Shopnbc VIZIO Gallevia 42" 1080p LCD HDTV
I have a RCA sound system with an hdmi port to plug into TV but the sound system will not turn on the tv will but not the sound system is there a fuse in the sound system to make it turn on that may have...
So to clarify, the T.V. turns on but the system doesn't turn on with it? Most external sound systems have their own and separate power supply. You will need to turn it on as well as the T.V.,
Elisa Jed ' http://www.fordtronicvideo.net.au/about-fvs.html
Apr 20, 2014 | Televison & Video
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Shortly after turning on my 2007 samsung 42" LCD TV, the sound turns off.
Since you just changed signal source (from what I understand) your first goal should be to determine if the problem is in your TV or your signal source, i.e. directv receiver (and btw aren't directv satellite and not cable service?!).
You do that by trying another source for the TV - DVD, blue-ray, over-the-air antenna, anything that is not your new sound source.
Once you know the sound is broken down by the TV and not the TV receiver (or the other way around) you can proceed with troubleshooting.
Oct 22, 2011 | Televison & Video
NO SOUND
Unplug,replug the tv about an hour later,let the tv reset itself back to factory setting.Go in the tv menu go to AUDIO.Go down to reset let the sound function in the Tuner baord reset itself to the correct setting.From now on ur tv should not lost suond, when turn tv off and turn tv on anymore.
May 06, 2010 | Panasonic TC-P50X1 50 in. Plasma HDTV
Tv + converter box = no sound
Try these steps: Turn the volume on your converter box all the way down. Turn the volume on your TV up to ½ way. Now turn up the volume on your converter box until it is at a comfortable level. More information at http://www.ezdigitaltv.com/index.html
Mar 31, 2009 | Sansui CDVD1310 13" TV/DVD
42" plasma tv
there may be loose contact in speakers inside....
take the technician & your problem will be solved........
Feb 05, 2008 | Creative Labs Sound Blaster Live! 5.1...
Apex Digital LD4088 LCD TV Logo
141 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
