Question about Maytag Atlantis MDG7400AW Gas Dryer
No Heat on any cylce
Mositure light not coming on, vent clear, drum turning and timer is working.
When that happened to mine i replaced the moisture sensor and all is well....easy and cheap.
Posted on Sep 02, 2008
Maytag Atlantis Series MDE6400AYW -- Current is good, brand new power cord, drum light comes on -- When I turn the timer, I can hear it clicking, but nothing else works.
You need a thermal fuse and check the venting heat is backing up causing the fuse to blow fuse part number 307473 located on the back remove back panel to gain access
May 30, 2015 | Maytag Dryers
Frigidaire Model FEQB2152FE1. Start dryer and after 5 minutes "Ad" code; lights blink dryer drum turns, but does not dry clothes
Check that exhaust air vent is venting air. If not, clear vent and retry.
Check that heating element is heating. if not, check overheat switch for continuity with power unplugged. If you don't have continuity get new switch. If it reads ontinuity then suspect the heating element.
Aug 20, 2013 | Maytag Clothes Dryer Almond Timer Knob...
LIGHT COMES ON IN DRYER, CAN HEAR TIMER, DRYER WON'T COME ON, HAVE CHECKED CONTINUITY ON DOOR SWITCH,HEAT SENSOR, START SWITCH
there are two or three heat sensors in a dryer one on the vent one by the fire/drum and one sometimes just for fun. Make sure you follow the wires and check all of them
Jun 16, 2010 | KitchenAid KEYS750LQ Electric Dryer
Heat is not always coming on in dryer. Roper dryer from Lowes
There are numerous temperature sensors on the dryer. Some are near the drum, some could be near the lint filter if it is located inside the dryer door. Try changing these first as they are an in expensive fix. It could also be the heating coils themselves. Highly unlikely it would be the dial, unless the dial was accidentally turned in the wrong direction.
Apr 26, 2010 | Roper REX4634KQ Electric Dryer
Whirlpool LER4634EQO Runs for about 2 minuts and shuts off.
It is possible your Cycling Themostat is not working properly. It determines at what temperature to turn heat on and off to maintain a consistent dryer temp. The High Limit Thermostat would turn off the heat but your dryer would still run. That leaves the Thermal Cut Off which is turning off your dryer. It might be faulty and turning off at too low a temp, or it might be doing it's job. In that case something else is wrong. If you can check the exhaust air temperature at the dryer, it should be under 175 degrees. If you are absolutely sure the vent is clear, then replace the Dryer Cycling Thermostat.
Aug 25, 2009 | Dryers
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
No heat, motion, but light is on and timer ticks
Check the thermal fuse on the blower housing. It is for over heat condition and non resettable.
eric
Jun 29, 2009 | Kenmore Dryers
GE Profile dpsr473ewoww timer doesn't work and heat level is low
We should address the heat problem first. If your dryer complaint is "heat seems low" or taking "too long to heat", this is commonly confused for other problems. When in fact, you may really have a "ventillation problem". Do you feel (with hand) alot of hot air pressure coming out the back of the dryer or house vent-line (for dryer)?
I would disconnect and clean the dryer exhaust vent/duct (at wall and machine). Then, while leaving the vent-line disconnected temporaily, test and run your dryer. You may see an signficant improvement.
Does it heat up better?
Do you feel alot of hot air and pressure coming out the back of the dryer?
When connected; do you feel alot of hot air pressure coming out of your house dryer vent?
MaintenanceUniverse.com
Feb 01, 2009 | GE Profile DPSR473EW Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
126 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
