Question about IBM THINKPAD T61P T7700 2.4G 2GB 160GB DVDRW 15.4-WUXGA AGN BT BFP PC Notebook
Nothing happens when I power up ... I have pulled the battery and waited then re-inserted battery and re-tried ... the only light that comes on besides the power light is the circle with "z" inside it light.
  • 6 more comments
  • ijglover Nov 04, 2010
    The light to the left of No 3
    I hear the fan but not the disk also there is an audible Beep (pause) Beep Beep
    I can try with your guidance
    Isn't the memory ubder the palm rest?
    I have 2 2gb memory modules installed new 2 months ago. I have re-seated them one at a time with the same results
    This is not my Hardware config ... my battery runs over 2/3 of the length of the back and sticks out 3/4 inch
    The second one "One long and two short beeps, and a blank or unreadable LCD."
    Thanks for your assistance ... I accept this solution
  • 4,889 Answers
Well I could not understand what you meant by circle with Z inside it. Can you tell me which on of them is it, from the image at the link below?
http://www-307.ibm.com/pc/support/site.wss/r61-t61-14.jpg
Posted on Nov 04, 2010
  • 6 more comments
  • eagle338
    eagle338 Nov 04, 2010
    Well the Z-light just means that the system is on. Do you hear it starting up?
  • eagle338
    Its a problem with your memory modules. are you willing to open it up and re-seat them?
  • eagle338
    OK lets see. Before you begin be sure to touch a grounded metal for a few seconds to discharge any ESD present in your hands. ESD is electronics' worst enemy. Next up close the lid and turn the laptop over. You will see a small plate kind of thing with screws. Remove the screws and then remove the cover. You will see the Ram modules, 2 of them 1GB each. Carefully remove both of them. Put one back in and see if it boots, then try the other. The beeps are due to dislocated modules but in some cases damaged modules. If re-seating them does not resolve the issue then its time for new RAM modules. The design flaws in some thinkpads cause them to die very soon.
  • eagle338
  • eagle338
    Ok. What about the hard drive? Does it match any of this sequences?
    http://www-307.ibm.com/pc/support/site.w...
    Note:DIMM = RAM
  • eagle338
    Ok. What about the beep sequence. Does it match any of these?
  • eagle338
    So you read what that says right? Its either the LCD assembly or system board and may be even DIMM(unlikely as you have replaced it just a couple of months ago). Time to get it serviced by IBM? I think so.
  • eagle338
    You are welcome. Thank you for using Fixya!
KDC-X997 Firmware update
If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Jun 09, 2016 | Kenwood KDC-X997 eXcelon Car Stereo with...
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
It will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
My laptop screen doesn't come on tho the power is on. Fan seems to be on. Cd player ejects and it loads my iPod. I did give it a restart command and it didn't respond so I shut the flap and when reopened I...
1. Remove the system completely from power by removing the battery and AC cable 2. Wait a few minutes then insert battery ONLY 3. Power system back on while continusly pressing the spacebar 4. If screen does not appear within SEVERAL MINUTES wait time please turn off by removing battery 5. PLUG BOTH battery and AC cable in and repeat above process 6. If still nothing happens, please return to me for additional help.
My username is bbl242003, just add a comment if need be.
Please do not forget to ACCEPT the best answer
Jan 09, 2011 | Gateway Computers & Internet
Try to turn Dell Inspiron 6000 laptop and nothing happens. No lights, no sounds, nothing. Power chord is good and has output voltage of 19.5.
remove battery and then insert power cord and power it up. if it powers, then insert battery while laptop is on. otherwise, if it doesnt, get the battery charged from else where and insert it just to confirm that the power supply unit isnt spoilt.
Regards
Feb 13, 2010 | Dell Inspiron 6000 Notebook
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Power supply
I think your problem is not with the power supply, its the hdd or memory thats causing the problem. try to check the cables, and re insert the memory then start up your pc again.
allen
Jun 12, 2008 | ASUS P4P800-MX Motherboard
Plz help
remove the SD Card and the batteries. Wait for half an hour and then insert two new batteries. Do not put the SD card in as yet. (Waiting for half an hour or more allows the camera to reset itself).
Now try switching on and good luck.
Dec 27, 2007 | Kodak EasyShare C653 Digital Camera
IBM THINKPAD T61P T7700 2.4G 2GB 160GB DVDRW 15.4-WUXGA AGN BT BFP PC Notebook Logo
91 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
