Question about Maytag Washing Machines
Maytag washing machince (top loading)
  • Did a normal load and when coming back into laundry room, there were two inches of water.
  • Looks like one of the two black hoses (1/2 inch diameter or so) has a leaking clamp or washer?
  • Please advise how to fix this and where to go for a new clamp and other parts...
  • 246 Answers
I'm not sure where you live, but first source parts is a nation wide company that carries (or can order) parts for most brads of washers. If not, usually you can order them trhough the manufactures web sites also.
Posted on Jun 13, 2008
Leaking into wash tub
The water inlet valve needs to be replaced. It is not sealing.
Here is a link to the part you need.
Aug 13, 2012 | GE Profile WPRE6100G Top Load Washer
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
The weather has caused the pipes to freeze in the house for the past two days. So I had to do laundry. So I started the load of laungry on cold, the washer started normal with water going in. So I...
The potential damage would be to the water inlet solenoid valves -- one for hot and one for cold. The chattering was caused by the valves trying to open and then closing over and over again.
The valves are the parts the hose screws onto on the back of the washer. More info, let me know.
Charlie
Feb 12, 2011 | Maytag Bravos MTW6600T Top Load Washer
Maytag Auto Load-Sensing Washer does not fill with enough water to wash the clothes. How do I get around this?
Did you ever get an answer - all I see are ads :-(
We have the same problem. Not enough water to rinse - even with extra rinse selected. Even our laundry comes out the color of the laundry detergent. I'm sure this is a result of government regulations to reduce water usage. We'll contact Maytag tomorrow.
Sep 07, 2010 | Maytag PAV2300 Top Load Washer
Very loud spinning cycle
was the shipping bolts removed when it was delivered there are four in the back
Mar 29, 2009 | Kenmore HE2 Plus Front Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Maytag discharge into wastepipe backs up, floods laundry room.
best approach is be sure to clean drain pipe build up over the years may have created partial blockage
Apr 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
