Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t
I am getting an error of F2. I washed a bath mat that had rubber backing on it. I think the rubber came off in the wash cycle and clogged the drain hose or filter. How to I clean out the filter? I appreciate any help you can offer.
  • Stacey 23 Jun 13, 2008
    Thanks Lumpy!
  • Stacey 23 Jun 14, 2008
    To clarify...You are talking about removing the 3 screws on the front bottom of the machine, right? Are they phillips screws? It is hard to see. Thanks.
  • 246 Answers
F2 is a drain erro. Take the 3 screws off the botom panel in the middle, bottom you will see a large white plastic looking pump. this unscrews counter clock wise. have something ready to catch the rushing water. The trap is probably full of the rubber backing or strands of the rug. After you unscrew it, there is a trap there that can be cleaned. You may have to repeat this a couple of thimes to get all of it out.
Posted on Jun 13, 2008
  • Toby Norton
    Toby Norton Jun 15, 2008
    Sorry, they are a nuber 20 torx bit. These are availible from most hardware stores.
When I wash a bath mat the spin cycle never takes most of the water out of the mat so it is heavy with dripping water and difficult to put into the dryer. When I put on only the 'final spin' cyle it...
If your bath mat has a rubber backing, that would prevent the water from being centrifuged out of the mat. Even if you laid the mat in the drum with the wet side outwards, it would still only have a limited effect on removing the water.
Jan 26, 2011 | GE Washing Machines
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washer stopped at begin of wash cycle
The problem seems to lie in the rubber backed mat. If the rubber has begun to peel of the mat it often-times get stuck in the drain pump. The best thing to do at this point is to disconnect the electrical cord, open up the machine, drain out the water as best as possible disconnect the power cord to the drain and the hoses. Clean out the drain pump. reassemble. You should be good to go., Unless the drain pump is burned out (left running plugged up too long) if thats the case, replacement of the pump may be neccessary.... Hope this helps...Good luck!.... Bill
May 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Elite HE3t which F21 code
I'm guessing the HOSE is the drain hose.
The goop is causing the drain motor to overheat causing it to report error. (luckily or it'd burn out).
Give it a empty load with nothing in it to see if it flushes it all out.
Just water.
See if it completes full cycle and check pump filter again to see if clean.
TIP. Make sure you check ALL pockets before you wash clothes.
Apr 16, 2017 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front-load
you must remove bottom panel ,,in the center front you will find pump,,remove pump filter,,always unplug first..it has slugg,..than after you clean filter run your unit once a month with a pint of bleach and hot water only..also wipe your rubber gasket or bellows with a touch of bleach..
Dec 27, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
240 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
