Question about Starbucks Saeco Italia Digital Barista Coffee Machine
The steam controll knob has come off, and I am debating weather or not to open the machine up and fix it. Any ideas advice or suggestions. I kow that there is no service for these things so you are pretty much on your own right?
  • 1,089 Answers
Hi
It snaps on. There are alignment pins that you line up and push in until it clicks in place.
Posted on Nov 04, 2010
Testimonial: "THis was very helpful , I was just at the stage of taking the machine apart, and found the exact thing that was explained. Thank you"
  • Merrit1999 Dec 14, 2010
    My steam knob also popped off. I tried everything to put it back inside, but it won't go in and now it won't even make espresso. Any suggestions?
  • jdbanana Mar 22, 2011
    When the knob popped off of my daughter's machine, the problem turned out to be a clogged steam wand. This is a safety feature because it relieves pressure. If you don't clear out milk every time after steaming by putting the tip into water and turning on the steam, it will become clogged. This can be cleared with a pin - - put a rag underneath because some foul-smelling rotten milk will come out of the steaming wand. After you do this you should be able to follow instructions above about popping the knob back on.
Reads "machine is rinsing open knob"
the internal motor is not running .so its not making noises as usual.
servicing required
Sep 18, 2008 | Starbucks Saeco Italia Digital Barista...
The steam function has stopped working, I regularly descale, but it just stopped working all of a sudden. Any ideas how to fix it?
Try this, using a paper clip make sure that the end of the wand is not clogged. If not then open steam wand and then push the knob in, if that works then the valve stem needs to be replaced, if it doesn't, can you get hot water from the valve, if yes then the thermostat or the element on the steam booster boiler is damaged.
Sep 10, 2009 | Gaggia Titanium Espresso Machine
Steam wand doesn't work
High pressure air using a blowgun?
Aug 24, 2009 | Saeco Starbucks Sirena Espresso Machine
Solis Palazzo Descaling (?) Problem? Please Help!
Hi
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
Jan 28, 2009 | Solis Palazzo Espresso Machine
Stema Knob wont fully stop flow of steam/water
Here is the link to the part that you need to change. http://cerinicoffee.com/Saeco_steam_valve_plastic_italia.asp
For Saeco Parts and Cleaning supplies visit www.cerinicoffee.com
Jun 18, 2008 | Gaggia Titanium Espresso Machine
Machine will turn on but that is it
The light 20 is power control light, 26 light if any problems are indicated on the machine and should only light if there are any trouble with the machine. 22 should light when the temperature is right.
Try to open the steam knob and make a cup of water.
Apr 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Water won't flow through the tubes
You might need to prime the pump manually since the machine has been moved.
directions:
Fill water tank.
Turn power on.
Open the steam knob all the way.
Press the coffee button.
Put a cup under the steam pump wand.
Wait until you see a steady flow of water and no air.
When you see the flow of water, close the steam knob.
Turn off the coffee button.
Now the machine should be ready to brew an espresso.
If that does not work you can contact the service center for more suggestions:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Mar 29, 2007 | Briel Chamonix ES-35 Espresso Machine
Steam knob is stuck in "open" position
I used brute force. Remember to turn it clockwise to close.
Oct 31, 2006 | Rancilio Silvia Espresso Machine
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
93 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Info2011
Level 1 Expert
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
