Question about Smeg FME24X Microwave Oven
Door latch does not catch ,yet light goes on and turn table turns but does not heat. what part is needed and special tools?
    Brigadier General:
  • 8,909 Answers
Possibly door catch and/or door interlock switch may be damaged.
No special tools are required, maybe a torq 20 screwdriver.
Posted on Nov 04, 2010
GE microwave light turns on when START buton is pushed and all the push buttons work but no heat, no sound and turn table does not turn. Any suggestions?
You might have a bad door switch, open thermal protector, or the latch mechanism is not activating the switches properly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Dec 03, 2016 | GE Microwave Ovens
MICROWAVE WILL RUN THEN TURN TABLE WILL STOP LIGHT GOES OUT AND STOPS HEATING THEN WILL TURN BACK ON AND OFF. ANY SUGGESTIONS
Sounds like either an intermittent door interlock switch or possibly a bad thermal fuse.
Nov 12, 2014 | Microwave Ovens
Why does Panasonic nn-sn651 usually work; but sometimes, turntable won't start ?
This is an inverter model so there is no diode or hv capacitor.
You must adt. the door latch switch assembly to make sure that the door hooks make contact with the switches. Common problem is that the assembly is bent and must be perpendicular to the door.If it is bent the switch will not make contact with the door hooks.
Place a dab of lithium grease on the tip of the door hooks to ease closing the door. This is the cause of the bent switch assembly!
Aug 31, 2014 | Panasonic 1.2 Cu. Ft. Mid-Size Microwave -...
My frigidare microwave model #FFMV162LB (about 5 years old) stopped working. I was cooking last night, and in the middle of it, the table stopped turning and the heat stopped. The timer still works and the...
After 5 years of service, there could have been a magnetron failure but the door interlock (latch) could have failed which would acccount for the turntable failure.
Feb 13, 2014 | Frigidaire FFMV162LB Microwave Oven
Magic Chef MCD1611ST Microwave Oven Door latch
1) see the diagram attached for to see the fuse, you must unplugged the power from the wall, and turn OFF the c.breaker from your house.
2) if the problem is the door latch see the video use the common sense.
God bless you
Sep 09, 2012 | Magic Chef MCD1611ST Microwave Oven
Turn table does not turn when heating. Interior light does not come on during cooking, works fine when door is opens.
some microwave is have PCB control if pcs is shorted some parts light bult,fan or syncronus motor is on mode we need to replace the pcb but some problem is only is micro switch,if mocro swict is rusty or corroded that the time not working the turn table,but you said every time open the door the ligth is ok,if the turn table also running during open door have problem in your pcb board that we need for replacement,but check the price of parts and make it desicion if you want to repair or buy a new one if your unit is very old.
Dec 28, 2010 | Microwave Ovens
Front door closes on a model R-1610-11-12 but light does not go out and microwave cannot be started up. Door does not seem to latch in place. In lower door latch inside the microwave I can see a plastic...
hi check that the door catch is locking into place maybethe locking mec is not engaging or triping the micro switch ,if it does n't trip the switch it won't turn light off and unit won't work
cheers grant
Oct 22, 2008 | Sharp Microwave Ovens
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Smeg FME24X Microwave Oven Logo
175 people viewed this question
Top Smeg Microwave Ovens Experts
William Miller
William Miller
Vincent_G
Vincent_G
Are you a Smeg Microwave Oven Expert? Answer questions, earn points and help others
