Question about Sewing Machines
Singer 2517---loading bobbin?
I haven't used my machine for awhile and when i took it out to do some mending it worked just fine--yay! That is until the bobbin ran out and now i don't know how to load it up again. Can you help me???
    Genius:
  • 1,036 Answers
Threading the bobbin - winding thread onto the bobbin.
Position the new empty bobbin onto the vertical bobbin rod next to the end wheel. Click the rod to the right to engage drive. Hold the outer end wheel with left hand, and rotate the inner wheel anticlockwise by about a 1/2 turn (it stops) this removes drive from the foot and needle mechanism.
(** See note below -)
From a spool of thread on the top, thread to a loop/post on the left on the top. Then back to the bobbin you want to wind. Thread through a hole from the inside-out. Hold the thread vertically above the bobbin while you depress the footswitch to start winding. Let go when it's turned a few times.
Move bobbin shaft left, and tighten end wheel after winding enough.
Fitting bobbin-
Move footplate towards you, insert bobbin in hole so that bobbin rotates anticlockwise when thread is pulled, then pull thread into the fine notch towards you. After this position thread away from you, and slide the footplate closed.
To start / load thread. Hold the end 3" of the thread through the needle behind the sewing foot. hand crank towards you to sew first stitch in air. This should retrieve the lower thread - which you can catch with a handy pair of scissors. Then pull both threads rearwards - ready to sew.
**Note -
If the threading spindle is on the top, push to the right to engage, On the earlier versions, you have to thread it through a wire hook, then down and around a plate with two slots near the bottom right, before winding around the bobbin which is held horizontally as a direct drive off the handwheel.
Hope this helps - If so rate as Fixya!
Otherwise we'll try again for you.
Thanks for using Fixya!
Posted on Jun 14, 2008
Where can a retainer that fits under the bobbin. My machine is a Singer 2517 C
Sounds like you are talking about the bobbin case. Go to any sewing machine repair shop and buy a bobbin case Singer #421326
Sep 30, 2014 | Sewing Machines
How do you remove and install a new spring tension on Singer 2517?
Good day to you!!!
Here are some links that could help you on removing and installing a spring tension.Please click the link bellow:
http://www.treadleon.net/sewingmachineshop/shuttle/vsshuttle.html
http://www.ask.com/questions-about/Load-a-Bobbin
http://sewing.about.com/od/sewingmachineindex/a/mtroubleshot.htm
for installing:
http://www.ehow.com/video_4437031_winding-bobbin-sewing-machine.html
http://supsew.com/KnowledgeBaseArtefacts/images/189-english.pdf
Please let me know if this solution helps you or not...If not I can make much helpful tips just add a comment..
Thank you...
Aug 12, 2011 | Singer 2517 Mechanical Sewing Machine
How do I thread the bobbon on a singer 2517 machine?
Go to http://www.singerco.com/accessories/instruction-manuals/search. Enter 2517 and you can download the manual for your machine for free. The instructions for threading your bobbin should be shown in there.
Good luck and happy sewing!
Jun 07, 2011 | Singer 2517 Mechanical Sewing Machine
What size bobbin do I need for my singer 2517? I need more and I don't know what size to get.
Try checking the manual. If you don't have one, go to http://www.singerco.com/accessories/manuals.html where you can download one for free. It should tell you what bobbin you need in there. I know both of my Singers tell me the type of bobbin I need for each of them in their manuals.
Apr 30, 2011 | Singer 2517 Mechanical Sewing Machine
Hi, I'm missing a bobbin case on my Singer 2517, where can I buy them ? Thank you.
Go to www.sewingpartsonline.com and you can order one for $11.99. This is a great spot for finding old parts. There are others but I have had good success with these people, fair prices and reliable.
Oct 28, 2010 | Singer 2517 Mechanical Sewing Machine
I am trying to thread my singer quikfix mending machine and the needle will not pick up the thread from the bobbin. Of course, the manual is useless. I wonder if the bobbin case is out-of-wack. Do you...
Call customer service, 1-800-4singer and get the answer. Heard they are a nightmare to thread. If, you can't get it to work return and by a Singer Simple for $99. at Joann's. They give you a lesson on it for free. Good luck
Aug 30, 2010 | Singer Sewing Machines
I've lost the manual to the Singer Tiny Tailor mending machine M100A and need to know how to refill the bobbins. Can you help me? Thanks
Jan 18, 2010 | Singer Sewing Machines
Sewing Machines Logo
636 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
