Question about Belkin (F5D7230-4) Router (587009)
What is a desktop card? Belkin Wireless G Router questions too.
I bought my son a Belkin Wireless G Router so he can connect his Wii to the internet. It says on the box that in order to connect with a desktop computer I need a desktop card or a USB adapter. I have a desktop computer, but does that mean only if I want to connect that to another desktop? If I need a desktop card or a USB adapter - what do they do?
Also, if I have a firewall on my desktop computer, does that cover the Wii also? I am obviously new to this whole thing. Thank you.
  • 2,794 Answers
The only thing you need is a network connection in the back of your computer if you are going wired or a wireless adaptor for each device if you want to connect that way.
I understand the Wii has wireless built into it but you might want to check on that.
Posted on Jun 13, 2008
I have just bought the belkin wireless g+ mimo and my wireless printer and my son's wii do not recognse it. It comes up with the name we then enter the pass key and it just doesn't work? any help please?...
the printer and Wii may not recognise WPA security type. change the security type to 64bit WEP. in ur router u'll have WPS(wi fi protected set up) , u need to disable it. this will make ur printer and Wii work.
Dec 27, 2009 | Belkin Wireless-G Plus MIMO Router with...
Belkin router signal not showing up for Wii or Laptop.
If no signal, check router config. Use your
internet browser to look at router's settings.
By default the password on most Belkin routers is left blank, and the default IP address is 192.168.2.1 Check all you router's wireless settings in case disabled or incorrect. Make sure the laptop's wifi button has been toggled to OFF. Routers do die - esp the lowend ones. New wireless G router = $20 on sale.
Jul 07, 2009 | Belkin (F5D5231-4) Router
I cant communicate with belkin wireless g router
It sounds like you don't have the units connected properly. Make sure you have a cable(wired) from your ethernet card on your pc connected to a wired port on the router. Then plug your router from its yellow port into the modem. Make sure your modem is connected to its Internet interface. Plug in your modem and wait 60 seconds for it to power up. Then power up the router.
At this point you should be able to access the router with the supplied installation CD. Run the setup assistant and it will define your wireless network. When you are through you should have internet access through the wired network. When you are finished you should be able to use the wireless network assuming you have the card installed correctly and the software for the card correctly installed.
Jul 09, 2008 | Belkin (F5D7230-4) Router (587009)
Random cut outs?
question: you have your wii connected to your internet
Jun 14, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot finish installation (Belkin F5D8633-4 wireless modem router N mimo)
ok, obvious questions first:
Do you have a different modem from TALKTALK? can you connect to the internet through that?
if so, you may not have to set a username and password for the belkin router: just connect the belkin router's internet port to the talktalk modem and let the talktalk modem handle the automatic connection.
do you know what protocol the talktalk ISP uses?  it's probably PPPOE; make certain that your belkin router is set to the correct protocol.  if you just hook it up to the talktalk modem though, you probably won't have to specificy a protocol at all.
Mar 29, 2008 | Computers & Internet
Belkin wireless router installation with a laptop that has an internal modem
Depending on the operating system that you are running, and if you have the appropriate wireless cards, you should be able to do this either with or without the modem. If you have the modem connected to one computer, and wireless cards on both computers, then your best option would be to just connect directly from one computer to the next. If you can tell me the answers to these few questions, I can help you get on the right path.
What operating system are you running? Windows XP? Vista? Macintosh?
Do both of your computers have wireless network cards? If not, then which computers have the wireless network, and which computer has the modem?
Feb 02, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Pc connection problems
Sounds like you are setup to use Internet Connection Sharing. don't do this. Have each computer connect to the internet via the router. If the router is wireless connect all computers wirelessly to the router that are wireless capable and any computers that are not wireless capable, connect them to the router via a cat5 cable to the cat5 ports on the router. This will solve your problem. BPCS
Dec 30, 2007 | Belkin (F5D5231-4) Router
D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Oct 31, 2007 | Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
60 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
