Phd now 091-935 contact support - Office Equipment & Supplies
I would like to know if this model PHd8000 is still available for purchase
Hello, Kimberly -
Clarification: Are you asking about a digital high definition (HD) television antenna made by Prime Tech?
If so, the answer will depend upon where (what country) you reside. So far, I have only found the antenna sold through Brazil based websites.
In case you reside in Brazil, see:
https://www.zoom.com.br/antena/antena-de-tv-externa-prime-tech-phd-8000
and
https://www.extra.com.br/tvseacessorios/acessoriosparatvs/AntenaseReceptoresparatvs/antena-digital-externa-prime-tech-uhf-phd-8000-suporte-para-antena-de-aluminio-phd-8000-sua-9289711.html
and
https://www.pontofrio.com.br/tvseacessorios/acessoriosparatvs/antenasereceptoresparatvs/antena-digital-externa-uhf-phd-8000-phd-8000-9124021.html
Best wishes.
Jun 19, 2018 | Televison & Video
Error code 007 340
Hello!
This issue relates to an error with the PHD (Photoconductive) Unit. To resolve this error please try the following steps:
1. Turn the printer off.
2. Wait 10 seconds.
3. Turn the printer on.
4. Determine if the issue still occurs.
5. If 007-340 or 007-341 Restart Printer Error recurs please remove the PHD Unit and remove any packaging.
To Remove PHD Unit:-> Remove the Paper Tray
-> Open the front cover.
-> Put a piece of paper on the transfer belt to protect it from scratches and from light damage. Do not cover the left and right of the belt guards with the paper.
-> Rotate the four stoppers of the PHD counter-clockwise 90 degrees to release the locks
-> Remove the PHD unit toward you by pulling it by the left and right handles.
-> Lift up the PHD unit from the printer. Be careful to avoid scratching the transfer belt.
-> Remove the packing tape by pulling straight out
Reinsert the PHD.
-> Close the front cover.
6. If error recurs with the PHD Unit re-seated please try another PHD from a working 2130CN Laser Printer (if available).
7. If issue recurs after trying another PHD or no PHD Unit is available, please call Dell Technical Support to advise.
Oct 28, 2013 | Office Equipment & Supplies
Does an old PHD cause faded colors?
the PHD transfers the image to the printed page and when it starts to go bad the images can become dull or faded and even blurry or totally missing. Id recommend the PHD be replaced and it should resolve your issues.
Feb 24, 2012 | Dell 2135cn All-In-One Laser Printer
Printer screen says to replace phd. what is phd?
PHD = Printer Head Device
It seems you need a new printer head.
More info. can be found here: http://support.dell.com/support/edocs/systems/prn2130cn/en/ug/sectiogd.htm#wp1189135
Hope that helps you ;)
Please Take a second to rate me! Thank You.
Apr 14, 2011 | Dell 2130cn Laser Printer
Printer says-replace PHD now- what does that mean?
Hi, The PHD unit is either missing or not fully inserted into the printer. Reinsert the PHD unit. See "Replacing the Print Head Device" in your printer manual.
thanks
Adam
please leave my feedback
Feb 18, 2011 | Dell 2135cn All-In-One Laser Printer
Asking to replace phd?
thanks
Adam
Jan 19, 2011 | Dell 2135cn All-In-One Laser Printer
Phd life over ??? como resolver?
This could be solved by: 1- Replace PHD (Image Drum) 2- Replace the PHD Chip (this only be used if the PHD can print correctly, without blurs or marks).
The chip also can be rewritten, but for this, you will need an EEprom recorder. If you still need, i can help you, i live in Curitiba, Brazil and here I have the solution for this problem. If necessary, contact me, i'll be glad to help you.
Nov 04, 2010 | TallyGenicom 8026DN Laser Printer
Hi i have a 1320c that doesnt print the black ink dark enough even after changing the cartridge
This is a know error and the only way to resolve is by pulling all 8 sealing ribbons from the PHD unit during first setup and installation? (4 in front, 4 in rear). When you open the printer box. There's also a very good setup instructional video on the CD.
If the 4 rear ribbons are still installed, remove them and print about 20-30 pages. If the print is still faint, you've ruined the PHD unit and you'll need a new one, Dell P/N DT574
Please let us know if you were looking for something else or please accept the solution. Thank You for contacting Fixya.com
Feb 23, 2010 | Dell 1320c Laser Printer
OSD locked Hisense PHD-4220
press menu, when osd locked appears press number 9 before osd locked disappears
Jan 11, 2009 | Hisense PHD-4220 Television
276 people viewed this question
k24674
Marvin
Marvin
