Question about JVC GR-DVL505 Mini DV Digital Camcorder
Busted Camera, Trapped Tape
My camera got wet, and so now it won't turn on. I am pretty sure it is broken for good, but i need the tape inside the camera. is there any special way to unscrew the camera to get out the tape?
  • 2,794 Answers
Usually you need power to get the tape to eject from the carriage.
Is the camera dry yet?
Posted on Jun 13, 2008
I have a JVC GR-DX25EK digital video camera which I have had for several years and never had any problems with. I used it yesterday to video my daughters wedding but when the tape ran out I couldn't...
The tape must be broken or rolled inside the camera, try to see if you can open the camera door a bit and force tape out. You will probably lose the tape.
Jul 19, 2008 | JVC Cameras
It says condensation and wont work
This normally is cause from of course condensation got wet or damp, and some times it is just that the tape area needs cleaning. Best thing first is try to new tape, then of course make sure it is dry, leave cover open and camera in warm area, if not then needs cleaning. mike
Jan 16, 2012 | Canon MV6iMC Mini DV Digital Camcorder
Battery cover broken
There's really not much you can do once the battery cover has broken from your camera. Depending on what brand/company your camera is from, they may replace it if it's under warranty. The best you can really do is get some tape and tape the cover, but even that won't provide a secure connection.
May 28, 2011 | Cameras
Fujifilm S1500. Batter compart doesn't close
If you can't return the camera for service, my advice would be to close the battery compartment with tape. Not pretty but better than buying a new camera, I've done it a few times on old cameras and apart from cosmetics, works fine. Just make sure to use enough tape so the batteries won't fly out when using it.
Jul 14, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
MY PANASONIC CAM RECORDER STOPPED WORKING BECAUSE
The tape will be badly damaged if trapped in camera, this always happens when the camera has got dirty heads and capstan rollers, some times the door wont open if this happens, but if it does open your local camera shop may get the film out.
Jun 16, 2010 | Panasonic NV-DS60 Mini DV Digital...
Tape is locked inside and cannot eject it. We took to a local camera shop and they said it would cost $200-$250 to help us get it out. I don't need to fix it if that is the case. I just need a player that...
The reason your tape wont come out the camera is because you may have not cleaned the record heads of late, they get tacky, grab your delecate tapes and twined them round the capstan and heads, then yes your little tape is well and truly stuck, trapped like a rat in a cage.
I have managed to get tapes out within a few minutes with a small screw driver and small pin, so I cannot see why they told you that stupid amount of money.
May 25, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
Sony's broken button issue
You need to use you fingernail and pop off the entire button assembly. When you have done this you will be looking inside your camera.
Set the new button assembly into the slots. It will not want to go on by just pushing down. The plasitc assembly is very slick so put a small piece of scotch tape the yellow stuff. I put the tape around the plastic assembly. Make sure you are only putting tape on the chrome plastic assembly. The reason for the tape is to get a good hold of the plastic asembly.
Once you have the tape on the assembly/chrome piece you need to really push down and twist clockwise. You will hear a click and then another click. Make sure you hear two clicks. I had to push and twist pretty hard to make it lock into place.
Jun 07, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Sony handycam CCD-TRV308
I was getting the same code and a dinging noise. I tried a cleaner and I tried letting the camera dry out...it wasn't wet! Neither worked. SOOO...Don't buy a cleaner. Look inside camcorder and make sure both reel turners are equal in height...they can slide down. Turn both of them...one of mine was down and also did not turn to make contact with tape. We got it to turn and the message C31:23 and the dinging quit. The stripes/bars also went away. Camera1.gif instantly worked like it used to. Good luck.
Dec 31, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Camera went swiming in salt water, But I need the tape!
1-800-ok-canon is the number unfortunatley there isnt a mauual way to open it without breaking something, in any manual posted. Best advice is to call and ask plus you can get a quote for repairs while your on...Sorry
Jul 29, 2007 | Canon ZR100 Mini DV Digital Camcorder
JVC GR-DVL505 Mini DV Digital Camcorder Logo
88 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
