Question about Garden
I have a 1980 poulan 4200, starts and runs, but no power and 'chugging' when throttled. replaced fuel line, rebuilt carb, no exhaust obstructions, compression is okay ~130psi what's next? Dan
    Brigadier General:
  • 4,088 Answers
Air cleaner may be plugged. This sounds like too much fuel going into the engine. When you serviced the carburetor, did you replace the diaphragm in the lower chamber and check the needle valve that the diaphragm operates? Did you clean or replace the fuel filter in the tank? If everything has been taken care of, turn both jet screws CW to stops (lightly), then back each out CCW 1-1/2 turns. Start the engine and allow to warm up. Pull the throttle full on, and turn H jet needle CW until the engine starts to speed up. Proper final adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW so that the engine idles fairly well, but will allow the engine to 'follow the throttle'. Adjust idle speed screw so that the engine continues to run, but the chain does not try to turn. Hope this helps!
Posted on Nov 04, 2010
  • namesmattern Nov 05, 2010
    I removed the air cleaner for testing. Fuel filter and line are both new. The diaphragm, needle valve, and rocker were replaced with the carb rebuild. the kit did not include new jet screws, which suprised me. I started by backing out 1 turn and going each way from there. It still seems to chugg at any setting. Do you think this might be a spark issue? maybe a dying ignition module or something?
    Thanks for your help. Dan
  • drallim Nov 06, 2010
    Did you wash out the fuel tank which might have had a residue of old oil in it? Check the ignition module gap clearance by removing the left side cover to expose the flywheel and module. Turn the flywheel magnets under the module poles, insert a thin business card in the gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws, and recheck for spark which should be blue and snappy. Make sure the plug is gapped at 0.020" and the insulator inside is a tan color. If black, then too much fuel (or excess oil) is going into the engine. When replacing the diaphragm in the carburetor, the gasket should go between the diaphragm and the cover. Go to: www.drystacked.com for a 12 page article on Walbro carburetor theory and troubleshooting. Hope we are getting closer to the problem!
Get my 1980 Suzuki GS8750L to run when I turn throttle..it starts n runs fine otherwise..idles wonderful
Is the fuel flowing freely? Definetly a fuel/air starvation issue. Something really simple such as blocked tank filter ,even a blocked exhaust,next doors cat isn't stuck up the pie nis it??
Oct 05, 2014 | Motorcycles
Poulan ym20cs won't stay running
Sounds like it needs carb adjusted and/or rebuilt.
Jun 24, 2014 | Poulan Garden
Engine will start and idle but stalls as soon as the throttle is pulled
This is typical of fuel starvation at the carburetor. If this unit has been sitting for awhile with fuel in it, the carb will need to be rebuilt with a kit or replaced. Once old fuel sits up in the carb it damages the check valve inside and/or hardens the diaphragms. Carb kits will work 50% of the time. Thanks, George
Nov 07, 2013 | Poulan Garden
1980 tr7 duel strongberg carbs. clean gas, pump works, rebuilt carbs. will not start! will run untill starting fluid burns -off.
Adjust the nut under the main jet needle to give it fuel to run with. The throttle control pushes the needles in too far and block of the jet so you have to give the jets a chance to allow fuel in
Oct 12, 2013 | Cars & Trucks
Poulan woodsman 2150 starts & runs for a few
This is fuel starvation, start by replacing the fuel filter inside the fuel tank, use a piece of bent wire to hook the fuel line and filter out of the tank, check the condition of the fuel hoses up to the carb, any signs of leakage and you will have to change the hose. See if this works before we go into the carb to locate the blockage.
Jun 09, 2013 | Garden
Poulan Pro Wild Thing will only run with choke out. Carb has been fully rebuilt and new lines added. As soon as throttle is pulled and choke pops off, engine dies. Any recommendations/suggestions? Thanks,...
If not already done replace the fuel filter in the tank, it is obviously fuel starvation, if no better increase the the fuel mixture on the H and L screws ( turn anti clockwise 1/4 turn on each to start with)
Feb 27, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a 18 4200 poulan chainsaw i have a new carb also new fuel lines it has a new coil there is plenty of spark but checking the spark plug after trying to start it show no fuel on the plug where to go...
Hi, i would start by making sure the fuel is on if that is an option on your saw. Then makes sure there is nothing obstructing the flow of fuel from the tank to the carb. You can check the lines by draining the tank the blow thru the tank with an airhose and make sure air is coming from the delivery line that hooks to the carb. if all checks out there, then you my hve a gasket on backwards inside the crb or your fuel flow screw needs adjusted. You can check to see if the carb has gas by gently loosining the drain bolt on the bottom. Another option is removeing the air filter and dumping a small amount of gas directly into the carb and see if it starts then. If it does then yo have a problem with fuel delivery from the tank to the carb into the cylinder head. Hope this helps.
Apr 05, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Engine stumbles under load, in varing rpm ranges
I have replaced the plug caps, wires, and coils on my three GL1000's.If it seems to happen more in the mornings or when it is wet. Start your cycle when it is dark and spray water onto the caps, wires, and coils (behind frame neck under fake tank shroud) look for sparks/arcing that might be the problem. Did you replace your fuel filter? Are the fuel lines in the tank plugged with rust? Did you replace the air cut valves and fuel pump diaphragms( old whens can be leaking or sticky)? Hope those ideas help, I'm guessing coils.
Apr 30, 2010 | 1983 Honda GL 1100 Innerstate Gold Wing
Blower does not seem to be getting fuel, last few usages required chock on to run, will start if gas poured in intake, but will not continue to run. cleaned out carb and fuel lines. What is the likley...
carb needs to be removed and thoroughly cleaned out,and rebuilt from varnish in the oil/gas mix,also remove the muffler and de-carbonize this also as it will create back-pressure and slow the rpm's and power output after time
Mar 23, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Starts but will not run
its a fuel issue. check fuel lines and fuel filter. If fuel lines are discolored or brittle or if filter has become unattatched from line- the fuel lines need replaced. Then carb needs adjusted ( turn low speed jet out 1/2 turn) or rebuilt
Nov 22, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
