Question about Zebra MT2090 Barcode Scanner PN MT2090SD0D62170WR Portable Terminal
I want my MT2090 running the same way as an LS2208 would. Just without cable. Means the craddle will be connected via usb with the computer. 1. I didn't find any usb driver that works. The one from motorolla, which had to be installed manually didnt work. 2. After the usb installation would be finished, do i need to do some configuration?
SOURCE: How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Posted on Feb 01, 2008
  • 7 Answers
SOURCE: UPS Thermal 2844 Connection problem(USB)
Add the printer as a Local LPT1. Then go into the properties and switch the port to a USB port. Try a test label. If it doesn't print, go back to properties of the printer and switch it to another USB until it does. If all else fails there is a remove utility included with the Zebra drivers you downloaded. You can remove all zebra related drivers and printers and then reboot. The PC should redetect the printer when you turn it on.
Posted on Aug 03, 2008
  • 7 Answers
SOURCE: Zebra 2844 won't print anything.
Sounds like you may have taken out more than the fuse. In case there is still life the next thing to try is a printer reset
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Posted on Jan 29, 2009
  • 35 Answers
SOURCE: Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Posted on Feb 16, 2010
  • 42 Answers
SOURCE: LS2208 displays no light
If the scanner is on a USB extension, they can be underpowered and will show up in the device manager but not work. This device like to be connected to a USB cord no longer then 4 ft or so.
Posted on Feb 23, 2010
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
Hi my name is christian canola and i purchased a symbol ls2208 barcode scanner from geminicomputers and i downloaded the program 123 scan2 for my barcode scanner and i click on my scanner is connected via...
Hi Christian, if your scanner was manufactured before February 2010 it may not be able to communicate directly with 123Scan2 so you wont be able to upgrade firmware with the program, but you will still be able to use it to create configuration sheets. These are the only two uses for 123Scan2.
To create a configuration sheet without "finding" the scanner click Create New Configuration then choose My scanner is NOT connected. Select the LS2208 and click on the blue firmware button to get into the configuration. When you have completed your configuration click the Print bar codes selection at the top of the window and when the file comes up be sure to click on the Bar code formatting menu and change the Bar code type to 1D One setting per barcode if it is not already there. Older scanners will not work with concatenated 1D barcodes where 123Scan2 puts more than one setting into a barcode.
Feb 12, 2011 | Symbol LS2208 Handheld
I have an Exilim X-Z50 camera but craddle is missing. Is there a way of downloading photos to the computer with just the USB cable connected directly to the PC? Is their a software for this purpose.
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 26, 2010 | Casio Exilim EX-Z50 Digital Camera
Dear sire I have symbol LS2208 handheld scanner (serial cable) but when connected in com port in a regular PC it do not power on .
you're going to either connect it to a com port that provides power, or get a different cable that allows you to connect an external power supply to it.
CBA-R01-S07PAR RS232 Cable assy, 50-14000-009R 220V PS,
or get a usb cable - program the scanner to USB, This will provide the power.
CBA-U01-S07ZAR-B
but only if you have an operating system that recognizes USB
Sep 23, 2010 | Symbol LS2208-7AZK0100S Handheld
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
Feb 01, 2010 | Symbol LS2208-7AZK0100S Handheld
I have a Symbol LS2208 barcode scanner with an RS232 connection. My new computer only has USB. Can I simply buy a new cable for the scanner, or do I have to get a serial-usb adapter to make it work?
You can purchase a USB cable for the scanner. The cable comes out of the handle of the scanner. The part number of the USB cable is CBA-U01-S07ZAR.
Sep 05, 2009 | Symbol LS2208 Handheld
Scanner doesn't turn on
Hello Loverboy,
the scanner turns on automatically as he he receives power from the host interface.
Please check the cables and connection. For RS232 interface would you need an external power supply. USB can power the scanner without external power supply. By Keyboard Wedge installation please connnect also the Keyboard.
Nov 09, 2008 | Symbol LS2208 Handheld
I am trying to install a cable modem with usb and ethernet connections on a windows xp computer.
Well there are 2 ways
via Ethernet
1.) connect the ethernet from the modem to the ethernet of the computer via the cable provided and thats should basically setup and give you an ip automatically
Via Usb
2.) install the drivers that came on a cd with the model
2.) follow the onscreen instructions and connect the modem via the usb cable when it tells you to
3.) when setup is complete it will create a connect icon for you, just run it to connect
Jul 14, 2008 | Computers & Internet
LS2208 barcode problem on Citrix
You you using USB versions of the device?
What device is hosting Citrix? (Maybe I should rephrase ... what computer is the LS2208 connected to and does it hold a citrix client)
Be advised that Citrix hosted on specialty devices like table pcs are finicky about the keyboard data timing (a synchronous operation)
Possibility #2 is power sag. When that scanner comes on it requires a lot of current, and often USB power (.5 amp max) isn't enough.
If you have a 15 foot USB cable on the scanner try a 6' striaght cable instead of one of the external power supply cables which provides a power pack and more power.
Nov 21, 2006 | Symbol LS2208 Handheld
Zebra MT2090 Barcode Scanner  PN MT2090SD0D62170WR Portable Terminal Logo
139 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Steve Allison
Steve Allison
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
