Question about Canon MV630i Mini DV Digital Camcorder
DV output I could connect the camera to my computer using a firewire connection. My new computer does not have a firewire connection. Is there a way to download the tape using the USB 2 connections on my new comuter? Then I use adaptors my Dell computer does not recongise the device. Is there a software programme required?
  • 1 more comment
  • John8591 Jun 13, 2008
    The new computer operating system is Vista. I can only find a software programme to recognise the camera on XP. Is there a Vista equivalent.
    Thanks but is the software programme avaiable for the Vista operating system?
    Is the software programme available for the Vista operating system.
    Genius:
  • 1,665 Answers
    Guru:
  • 1,342 Answers
You should be able to get everything you need for your camera HERE from Canon.
Free Pinnacle Editing Software
Posted on Jun 13, 2008
    Master:
  • 848 Answers
You can download using usb . the firmware can be updated from various sites . the software programme is also available
  • gopinath pasupathy Jun 24, 2008
    it is also available for vista programme
    Master:
  • 555 Answers
You can't convert a FireWire cable to a USB cable with just an adapter, or even with software.
  • Matt Jurach
    Matt Jurach Jun 13, 2008
    You need to use a USB cable, connecting the USB2 port on your new computer to the USB out on the camera.
  • Matt Jurach
    Yes, it is available for Vista. Just select "Vista OS" from this webpage at Canon.com
I purchased a Pinnacle Dazzle to connect my Sony DCR-HC38 to my computer. I do not know how to connect the camcorder to the Dazzle device.
Sony DCR-HC38E should have an interface called 1394, or the firewire. so you need to use a FireWire cable to connect it to your computer's firewire interface, some laptops have it built-in, If you don't have one on your computer, you can either purchase a IEEE1394/FireWire adapter, which should be under 100 or even $50.
Connector Type1.0 x Composite video/audio output , 1.0 x S-Video output , 1.0 x USB , IEEE 1394 (FireWire/i.LINK)
Sep 09, 2011 | Sony Handycam DCR-HC38E Mini DV Camcorder
Connect JVC GR-D240ek to vista laptop
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Jun 18, 2009 | JVC GR-D240 Mini DV Digital Camcorder
I have panasoni nv gs22 mini dv digital camera, I could connect to my laptop and copy the vedio
You can use an USB analog to digital converter for the analog outputs or the firewire/DV/iLink connection for the digital output, with the capturing software you can then have your videos on files or disks.
Feb 08, 2011 | Panasonic NV-GS22 Mini DV Digital...
Hi, I am trying to import from my Canon MV 600 ( Tape not digital ) into a mac pro. I got the DV to firewire lead but the computer doesnt seem to recognise the camera. Many thanks Billy
Hi in order to get footage off your camera through Firewire i.e DV you will have to use a software to capture the footage. You can use iMovie to capture the footage off the camera.
Open Apple System Profiler (it's in the Utilities folder) and check to see if your camera appears in the FireWire section.
If your camera is connected via FireWire and is turned on, follow one or more of these tips to re-establish the connection to the camera.
  • Turn the camera off and back on again.
  • Disconnect the FireWire cable from your computer and reconnect it. Do the same at the camera as well. If the camera is connected through a FireWire hub, try connecting the camera directly to the computer.
  • Some cameras need to be set to "VTR", "VCR", or "DV" mode in order to communicate with a computer. Check your camera's documentation for information on how to set your camera to this mode if needed
Hope this helps.
Jan 17, 2011 | Canon MV600 Mini DV Digital Camcorder
I have a Panasonic PV-GS39 and want to put my movies onto computer that's running on windows 7. Using the USB cable doesn't work. Will the firewire cable really work or am I just out of luck? Thanks for...
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Whether this will work with Windows 7, I am not sure. My Mini-DV camera, using a Firewire cable, didn't need any camera driver loaded to the computer, just the movie editor that came with Windows XP.
Dec 07, 2010 | Panasonic PV-GS39 Mini DV Digital...
How do i load tape to computer?
The simplest solution is to use a FireWire cable connected between camera DV output and FireWire PC Input.
If your PC or laptop do not has a FireWire Input, you can use an USB capture device like EasyCap connected to your PC by USB interface and to your Camcorder by RCA connector or S-Video connector.
Nov 25, 2010 | Sharp Viewcam VL-Z3H Mini DV Digital...
Lost disk to be able to download video onto computer
Download free application WINDV (Small Windows utility for DV FireWire digital video input/output ).
buy and connect a firewire cable between camcorder (DV output ) and a firewire input in your pc, if you not hasn't got one, buy it. you can buy a card with this kind of inputs.
Connect and run application, play camcorder, and record to your pc, your video.
Dec 05, 2007 | Samsung VP-D103i Mini DV Digital Camcorder
Dcr-vx2100 dv interface connection problem
camera firewire connection will not respond to iMovie or Finalcut even when using a new cable - what could be the problem?
Nov 12, 2007 | Sony Handycam DCR-VX2100 Mini DV Digital...
Capture digital video using Panasonic PV-GS12 and USB
Here's what I learned. 1. Connect with FIREWIRE. It's all of under 10 bucks if you shop around. 2. Use WINDV to capture if you need to. Hint: Free. 3. Use better software than what comes with the camera.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Canon MV630i Mini DV Digital Camcorder Logo
107 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
